I have a 2000 Honda Civic EX coupe with a just an intake on it. I have Koni Yellow adjustables shocks and Eibach Pro-kit shocks. I don't race the car. It's a daily driver so a nice ride quality/handling balance is important.
My car has a stock front sway bar of 22mm so I'm not removing it for something slightly bigger. I do want to purchase a rear sway bar to help make the handling more neutral. I've narrowed it down to: Comptech adjustable rear sway bar/lower tie combo ($359.10 at Lightning Motorsports) http://www.lightningmotorsports.com/...suspension.htm Suspension Techniques rear sway bar. ($139.26 at Lightning Motorsports) www.lightningmotorsports.com/suspension_techniques.htm What do you guys and girls recommend and why? What mm thickness is the Suspension Techniques bar? Where can I find the best price?
My 2000 Civic EX Coupe |
Re: Comptech or Suspension Techniques rear sway bar?
Sounds Like a question for CivicSIRacer adn Jackassi... those two know their shit for sure. Also there are a few other threads about kinda the same thing that I have read. Might want to check them out as well.
DoubleTap |
Look at the diameter size of each bar and determine which one will suit you better. The harder you push your car's handling, the thicker of a bar you'll want. Id probably go with the Comptec bar though if you have the $$$ for it since it has the integrated lower tiebar with it. That will insure 100% compatability between those 2 pieces. Also if you have or plan on ever getting a cat-back or rear section exhaust system, piping clearance to the bar and endlinks might come into play with certain bars. I know with my ITR rear swaybar I have on my '00 Civic coupe, that clearance is about as close as it can be without causing problems. "2.36 piping along with a 22mm bar = TIGHT tight fit!
Silver '00 Civic EJ6 Coupe PureHonda original member since Feb. 2000 D-series revolution For pics of my baby, click here! All rights reserved... All BITERS served! "The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket." i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift hessemer69 on AIM |
Doubletap - Silver here is insulted you didn't mention him.
After reading some more on Honda-tech about ripping out subframes with anything but a comptech, I've decided to go with the comptech. It's a real nice piece that is made just for my car.
The comptech would be better, there is also an ajustable rear sway/rear tie from ST - $350.00
The ST bar is 7/8" about 22.2mm Like SilverY2K, the exhaust may be an issue. Bend the exhaust, rear sway is more important. |
Re: Re: Comptech or Suspension Techniques rear sway bar?
Re: Re: Re: Comptech or Suspension Techniques rear sway bar?
I like scraping the paint off my exhaust piping with the top of the right side endlink to my swaybar (seen below). ![]()
Man Can't believe I forgot to mention yo SilverY2KCivic. My appoligies as I have also learned a shit load of stuff from your posts as well. I'll make a note and be sure you're in there next time.
DoubleTap |
