Old 12-17-2003, 10:27 AM
Jacleary Jacleary is offline
Send a message via AIM to Jacleary
Swap
just wondering. Will the 4g63 turbo engine and all wheel drive trans fit in the rs eclipse with out major work?
Old 12-17-2003, 12:29 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
NOPE, your looking at close to 8-10 grand to do that swap!
Old 12-18-2003, 12:34 PM
Thanks
Old 12-20-2003, 04:12 AM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
YEA THATS WAY TWO MUCH WORK
Old 12-20-2003, 05:47 PM
duckydsp's Avatar
duckydsp duckydsp is offline
With that extra money, you can just get a gsx.
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 01-03-2004, 02:59 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Re: Swap
You're better off just buying a gsx. The time and money you spend on that kind of swap would only be a continous headache.
V8's are like tampons, every pussy needs one!
Old 01-03-2004, 06:34 PM
gs-t spyder gs-t spyder is offline
Re: Swap
ya not really worth it. the 2.0 under your hood is backword of a gs-t or gsx 2.0 and is not that great of a motor anyway i would go with getting a turbo kit for your rs from hohn racecraft because then you are running a higher compression on your stock motor so you can run a smaller psi meaning on my 2.0 4g63 motor i can be pushing 19-20 psi and u pushing 6-7 psi and creating the about the same HP. just get a stage 1 or 2 and you would be more than happy probably get u into the 13's in the 1/4 mile on stock street tires. which is crusing pritty well for a car with out puting to much into it ($) i would guess that the stage 1 kit would cost some where between 1,600 to 2,400 dollars which in my mind id rather spend that then trying to swap the motor's and give you more that a 4g63. hope this helps U.
Old 01-03-2004, 09:30 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
apparently the word on the internet is that its impossible to cost tons of money
actually I talked someone who did it for about 3K.
complete 1G in a 2G n/t
does take some custom work and the wiring is a bitch but its more than possible
I'll post the pix, but i dont want to steal his glory
you'll see a Vfaq on it soon enough
-Agim
