Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 12-17-2003, 10:11 AM
tpickering tpickering is offline
Roof Rack
I'm looking into putting a roof rack on my 03 double cab. I like the roof rack they put on the nissan frontiers. Anyone know if a frontier roof rack will fit on a double cab tacoma? If not, what roof rack would you recommend?
Old 12-19-2003, 11:31 AM
'03DC3.4TRD4X4 '03DC3.4TRD4X4 is offline
That Nissan rack is only rated to some 50 pounds. Kind of weak in my book. Toyota has offered a rack for the DC but it has been discontinued. You could probably still find one if you are motivated to do so. Ebay?
Other than that option which I believe will have the same limits as the Nissan's, I have used Yakima racks for two decades now and love them. I have put upwards of 400 pounds on my trucks camper shell rack-- this I do not recommend but as I said, I had no problem. Yakima sets limits to 90-100 pounds per bar, but this is for insurance purposes I suspect. These racks are stout.
Come up with some custom mounts and you could bolt down any number of aftermarket basket-type racks. Con-Fer, Jaos, etc. If you live in an aftermarket paradise like California, it should be a cakewalk to find a fabricator but I recommend getting some references first since you are talking about permanant bolts through the roof into the pillar structure. But this would allow you to carry copious amounts of gear--this will cause a center of gravity change which can make all the difference in a fun outing into the mountains or a nightmare scenario with your insurance adjuster!
Old 12-19-2003, 12:11 PM
coolerthanice coolerthanice is offline
You can still buy DC racks. Go here: http://toyotaparts4u.com/ or try eBay. I think they are rated up to 70 lbs, but they fit and look slick.
Old 08-03-2004, 07:45 PM
robsatx robsatx is offline
How difficult to install?
Anyone?
Old 08-03-2004, 07:46 PM
Re: How difficult to install?
Originally Posted by robsatx
Anyone?
How difficult to install? Anyone done it before?
Old 08-04-2004, 07:14 PM
I installed them in my car and the installation is easy if you know what you are doing. The bolts that come with the toyota aftermarket ones allow for you to drop an the anchor in and screw in the screws without having to get under the roof, or above the headliner. I, however, had no idea about that and used my own bolts and had to remove my headliner, etc. Even by doing that it did not take long, maybe a few hours. I dont recommend you spend the $300 the toyota stealership, and actually a small bodyshop quoted me on.
Old 08-04-2004, 09:08 PM
Re: Roof Rack
Thanks for the info . . .
I like the roof rack on the Nissan better than the Toy, but like the Tacos much better . . .
Old 01-10-2005, 09:28 AM
Natedogg34 Natedogg34 is offline
Re: Roof Rack
Does a standard rack like Yakima or Thule fit on a D/C (without a shell--ie., using tabs in the doorframes)?
If so, does anyone know which model to use?
Thanks
