Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 12-17-2003, 09:57 AM
adarma1 adarma1 is offline
HELP: A4 Transmission Problem?
I own 1999 Audi A4 2.6ltr which is having a weird problem. when the speedometer passes between 40 and 60km/hr, i feel a vibration on the whole body of the car. But when it passes 60km/hr (also before it reaches 40km/hr), the vibration is gone. Until now the assumption of the problem is pointed at the transmission (that is according to the audi dealer). Is it a problem if i use the other ATF oil instead of from the Audi itself? i am using Dexron III Mobil 1. the dealer said i should use the original Audi ATF oil to solve the problem. Any more ideas what kinda problem i have with my A4 and how to resolve it? thanks in advance.
Old 12-17-2003, 09:01 PM
Glenn Peters Glenn Peters is offline
Re: HELP: A4 Transmission Problem?
You should be using the Audi fluid in your trans!!!!!!!! I have heard of center drive shaft issues on Quattro models, causing strange vibrations!!!!!! Question have you had your wheels balanced ? Remember Audi fluid in the trans!!!!!!! Your friendly audi tech.
Old 12-18-2003, 08:30 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...and its a 2.8, not a 2.6
SOLD!
Old 12-18-2003, 08:39 AM
wow..that's what i heard fr the audi tech in here as well.. i will change the trans oil with the orig then..however about the problem, it occured the day when i have the bonded rubber mounting for the transmission & tie rod been replaced at the dealer. Might it be coz of the problem as well??
Old 12-18-2003, 08:45 AM
My audi is 2.6 ltr not the quattro (12Valve ABC engine) . It's the asian version
i havent had my wheel balenced. FYI 2, one of the front shock is having oil leak as well but not yet a severe one
Old 12-18-2003, 08:46 AM
marked001's Avatar
Moderadur
Re: Re: HELP: A4 Transmission Problem?
ooohh...ok I didnt realize where you were from
SOLD!
Old 12-19-2003, 08:04 AM
I have just balanced my wheels and i found out that both front wheels are bad. I swap those fronts with rears then , hence the vibration is still there but better. I am gonna swap four of them with others tommorow at the dealer..see if that the coz of the vibration. If not then my trans is broken or something gonna fill it with the original audi fluid though
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
