Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-16-2003, 08:36 PM
victor victor is offline
Idle RPMs
Hi everyone,
My 1997 Maxima SE Manual (all stock) all of a sudden started to idle at 1000 RPMs. Used to be 600-660 RPMs. Does anyone has an idea what could it be?
Thanks
Old 12-16-2003, 11:36 PM
borriss borriss is offline
Re: Idle RPMs
Originally Posted by victor
Hi everyone,
Thanks
Stuck throttle cable, faulty coolant temperature sensor, malfunctioning IACV(idle air control valve), stuck fast idle cam, stuck cruise control cable or servo motor, bad TPS(throttle position sensor), ECU is gone, leaking air intake housing, foreign subjects in involved areas. Could be more I forgot to mention or don’t know. Did you get some trouble codes?
Old 12-17-2003, 06:22 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: Idle RPMs
a lot of people come on here with the same problem problem and the most common fix is a new idle air control valve as boriss said or even a cleaning if possible. it's nice when knowledgable noobs come through here. what up boriss. i mean no offense to victor in any way, it's a valid question.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
91 525i idles at 5000 RPM!!!! HELP!!!!! Metalmatt87 5 Series 0 11-13-2010 12:09 PM
Nissan Cefiro - Idling/driving rpm problem fnasir Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 10-01-2010 11:35 AM
2000 Grand am se...bad idle and stalls weis_01 Grand AM 3 09-20-2010 12:50 AM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 12:27 PM
Low idle RPM/rough idle and SES Doranpalmer Problem Diagnosis 1 03-23-2008 11:33 PM
