Old 12-16-2003, 04:47 PM
zxkevinxz zxkevinxz is offline
Question tire size
what are the biggest AT's i can fit on my stock rims w/o any rubbing?
1986 CJ-7 Renegade
Old 12-20-2003, 06:58 PM
poncho62's Avatar
poncho62 poncho62 is offline
Send a message via Yahoo to poncho62
Re: tire size
I have 235X75-15s on my 83 S10 4X4. Doesn't rub, but I wouldn't go any larger. Comes close to rubbing.
Old 12-20-2003, 09:49 PM
airforceone's Avatar
airforceone airforceone is offline
Send a message via AIM to airforceone
Is your S-10 2wd or 4wd?
The world's greatest Air Force...well, at least we blow up the most stuff.
Old 12-20-2003, 10:02 PM
poncho62's Avatar
Re: tire size
4 wheel drive
Old 12-21-2003, 09:33 AM
Re: tire size
2wd
1986 CJ-7 Renegade
Old 12-22-2003, 05:38 PM
TopDogg TopDogg is offline
I just resently went through the whole aggrevating tire size choice too. What size rims do you have? My guess is 15". I have 225/70R15s on 15x7 rims. I could of went with 235/70R15 but that would of been to tight. I seen a 96 2WD with 225/75R15 and he said they didnt rub but it sure did look like a full wheel well.
So if your running a stock rim you probably wont have to worry about tire being to wide. If so wheel spacers are an option. 225/70R15 tires are 27.4" in Diameter. You can push it to 28" with a 235/70.
I dont have ATs though. I have BFG T/A radials. I will soon be lifting the suspension 2" so I can fit 235/75R15 (29"Diameter) Yokahama Geolander AT + II tires. This set up will bring the 2wd S10 equal with many stock S10 4WDs.
Old 12-27-2003, 07:28 AM
radianguy's Avatar
radianguy radianguy is offline
I have a 4x4 and I have Lt235/75/r15's with no rubbing problems.My summer tires are p235/70/r15's and they look way too small.The Lt 235's fill out the wheel well much nicer.Also give the truck another inch of ground clearance.
2004 toyota Tacoma TRD 4x4
2003 Polaris 600 Classic Touring
2003 Yamaha YZF 600R
Tire pressure affect on tire size SPLThunder Engineering/ Technical 10 02-17-2008 04:30 PM
Tire size, rim size, how big is your limit? krackaboy1 Nova 0 05-01-2006 08:57 PM
Tire size poll Schludwiller Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 19 11-04-2004 11:37 PM
Tire size? Koojo Tires and Wheels 7 06-08-2001 05:29 PM
