Go Back   Automotive Forums Car Chat > Buick > Century
Old 12-16-2003, 04:30 PM
everlow everlow is offline
1991 Stalling, shuddering, slipping, idleing high
Yes, it does and seems to do all these things. I've done some extensive research online and have gotten multiple possible solutions, although nothing definative.
Here is the issue:
When travelling at any speed the car will stall/shudder/ and-or /idle-high. Sometimes it just stalls, idles high, seems to slow down, or starts to shift gears while depressing the gas pedal, by themselves. It seems like something is mis-firing ---- a switch, wire, or something is corroded or loose.
I took it to the shop once. They had it all day, took it on numerous test runs, and had no problems what so ever (cost me $60 for that). I drive 80miles per day through backroads and would rather not be stuck somewhere. I can't take it to the shop because the check engine light rarely comes on and they would not be able to do anything.
Is there anyone out there that has a definative answer as to what this is. People are talking about it all over the internet, but no one knows for sure. If needed I can give a list of possibles, and a list of what it's not (things people have changed but the problem still exhists). I won't do that here because I'm just rambling now -- sorry.
Thank you
Old 12-17-2003, 12:41 PM
RABarrett RABarrett is offline
Re: 1991 Stalling, shuddering, slipping, idleing high
These issues will include such things as what controls ignition and injection directly, with loss of these signals resulting in no backup. These include air flow meter, cam and crank signals, ignition signals from the module to the plugs etc. It may be possible to pull codes from the computer, allowing clues. Ray
Old 07-05-2004, 06:06 PM
motormack motormack is offline
My buick was stalling after it ran for about 45 minutes when you came to a stop it would stall.......was some electronic gadget on the transmission ....disconnected it and it runs fine
Old 07-06-2004, 08:45 PM
My mechanic friend unplugged that same wire for me, but to no avail. My garaage had it for about 2 weeks, changed a couple things on it, then we FINALLY found the problem --- bad computer. It has now run fine for about 8 months now.
Sp I spent about $450 for a $80 fix (used computer). Oh well, live and learn.
Old 11-09-2004, 08:36 PM
howied howied is offline
My 1991 buick stalls after running for 1/2 hour or so. put in gear and stalls.
Runs great when cold
any suggestions?
Old 11-10-2004, 05:47 PM
public's Avatar
public public is offline
TCC Solenoid. Disconnect to test.
Yes, I am retarded.
2001 Pontiac Grand Am: high idle, high rpm shifting gustie07 Grand AM 16 01-17-2015 02:56 AM
96 Cutlass Supreme 3.4L DOHC Idling high and not shifting properly 96cutlass3.4 Cutlass Series 8 06-18-2010 04:46 PM
94 Bonneville either stalls while coasting or idles high parnellij Bonneville 6 09-27-2009 10:08 PM
95 Max - Engine Shudder, Exh Sputter, & Stall Symptom while idling @ stop OrigJunior Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 25 08-03-2007 08:10 AM
