Old 12-16-2003, 04:17 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
How hard to install new brake lines?
My brakes become super spongy after a few hard stops. After that, when I hit the brakes almost nothing happens. This really, really sucks when autocrossing or going down the strip a few times.
I want these ($125):
All Earls brake lines are fully D.O.T. approved. These are direct replacement to the OEM rubber hoses, no modification required to install. Stainless steel brake lines eliminate the expansion that occurs when using rubber hoses, increasing braking performance up to 30%.The pulsing and spongy feeling that occurs with ABS equipped cars will be virtually eliminated. These kits includes all bolts, washers, locating tabs and inline brackets for a direct fit.
So anybody installed them on their car? Do you like them? How long did they take to install?
Old 12-16-2003, 10:15 PM
94civic's Avatar
94civic 94civic is offline
i got them, i like them and its pretty easy to install. go to jdm hondaparts they have them for $96
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 12-16-2003, 11:01 PM
Ricochet's Avatar
Banned
Re: How hard to install new brake lines?
cool thanks
Old 12-16-2003, 11:06 PM
BullShifter's Avatar
I don't personally have them on my car, but have installed & test drove many cars with them. There is a difference with hard braking & well the $$$.
Install is pretty simple. You need a flare nut wrench for the factory line/hose connections. No teflon tape. Make sure to replace the washers & don't over-tighten any thing. 25lb-ft @ the caliper connection // 10lb-ft @ line connection.
Since you must bleed the brakes after, now would be a good time to flush out the fluid with some Super Blue Racing. Clean/adjust/lube your brakes while your at it.
Old 12-16-2003, 11:13 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
yeah a good part of your problem could just be needing to flush the old fluid from your lines but SS brake lines are great... def worth the $
LS1 RX-7 Zoom Zoom
Old 12-17-2003, 09:40 AM
Ricochet's Avatar
Banned
Re: Re: How hard to install new brake lines?
I've got some money saved up and am going to buy EBC Greenstuff pads, silicon brake fluid (Super Blue most likely), and install these brake lines. Thanks for the help, I don't have a torque wrench but I should be alright.
Old 12-17-2003, 10:04 PM
Re: Re: Re: How hard to install new brake lines?
You don't need a torque wrench, just dont go crazy and you'll be fine.
After the install, make sure to pump the brake pedal & check for leaks. Don't put a lot pressure on the pedal when its hard, this is when seals blow out.
Old 12-18-2003, 04:50 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Weird, I never get fade or a spongy pedal with my car when I auto-X (and people say I use my brakes when I race more than I should, LOL!). I still have my OE rubber lines on as well. But I AM gonna upgrade to SS lines myself very soon here.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
How do you open brake line clips? sixseas Metro 3 10-12-2010 10:39 PM
quick question: how to make new body lines? intuned Car Modeling 6 07-12-2009 11:54 PM
How can I find brake line information? joema Silverado 2 11-16-2006 01:21 AM
Any pointers for new brake lines? joema Silverado 18 09-21-2006 08:18 PM
Anyone install new brake lines? FourthGenHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 6 09-04-2002 02:53 PM
