| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
bosch KE Jetronic pressure actuator
I am having trouble with my car not running. It will start but shuts down after about 2 seconds. I have removed the injector feed pipes and found no fuel flowing through when the engine is cranked. I am suspicious of the pressure regulator mounted on the side of the fuel distributor. Does anyone know how to test it? There are two wires on it which I assume come from the ECU.
Hmm,
KE by Bosch is also known as CIS.
On a BMW I will supply a diagram and the pump pressure testing. From the pump the pressure should be 71 psi. ![]() ![]() ![]()
have u checked ur fuel pump? on my RS Turbo it went and did exactly the same thing. fuel pump had just siezed.
Re: KE Jetronic
Thanks Ron, Tried the pump and OK. Put it all back together and now working fine. Maybe the Gremlin went away. Thanks again for all the info.
Re: bosch KE Jetronic pressure actuator
Jeebus ron! do you think you could be a little MORE helpful!!
Sheesh!
Mustangs are nice, but I'd rather have one of these...
Being English and an AF Newbie,I dont see what Mustang has added to the discussion. .Does the Smiley mean only kidding or what. Maybe I need a lesson in American humour.
Re: Re: bosch KE Jetronic pressure actuator
In short, mustang has not added technical information to the discussion, but he has given Ron a "pat on the back" for his post.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me... |
Wow Ivymike, that post was equally as comprehensive as rons, but in an entirely more humorous manner.
congrats.
