Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
View Poll Results: which tires...
Hoosier A3SO3 (autoX) 2 66.67%
Kuhmo Victoracer V700 1 33.33%
wait till right before the jan event and get something new 0 0%
Voters: 3. You may not vote on this poll
Old 12-15-2003, 09:22 PM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
Exclamation sticky tire advice
well, it's time for some dedicated race rims and sticky tire, however, they still need to be DOT legal. these WILL NOT be everyday use driving tires (that's what Falkens are for ), but mostly for AutoX use, with the occasional drag race night, or track day. i've come down to either Hoosier A3SO3 (the autoX tire) or Kumho Victoracer V700's. i've seen that the Hoosiers were preferred at Nationals, but i'm not sure if the slight time gain is worth $62 a tire more.
i've also recently heard that some of the other race tire manufacturers are coming out with some new tires that fit my application, specifically Toyo. i'm leaning towards the Kumhos or Hoosiers, as the new line won't be proven yet, thus, also more expensive.
my question here, is should i wait for the new products to come out (which i'm leaning more towards 'no', unless someone has some insight), or just go with my first choices... then it's the Kumho's or Hoosiers.
this would all be for a 225/50/15 tire on a 8" rim
on an '85 Mr2 putting out close to 250hp
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 12-17-2003, 11:02 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: sticky tire advice
check out mickey thompson.
I've had good luck with their E/T series tires on my old car that I used to drag race.
Old 12-17-2003, 04:55 PM
ac427cpe's Avatar
um.... very little drag racing will be done with this car. though those tires look cool... i don't think wrinkle walls will be too good for cornering, and as i'm much more of a lover of turns than straight lines... i don't think they'll work. thanks though.
hello, i am Dan
Old 12-23-2003, 10:31 AM
immagirl immagirl is offline
I say wait if you have not gotten them already something better will come out unless you plan on doin some damage to you car more soon than later. If you dont wait I would go with Kuhmo for your car. My friend has the same car and the same tires that you are looking to buy. His work perfectly for race day.
