Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-15-2003, 07:18 PM
wintergreen23 wintergreen23 is offline
bell housing coolant leak
98 Ram 1500 ia leaking coolant from the bottom of bell housing and does not appear to be coming from the intake manifold.Is there a freeze plug behind fly wheel that could be the problem,help.
Old 11-21-2004, 01:02 PM
options13 options13 is offline
Re: bell housing coolant leak
Hi, Was wondering if you ever figured out where your leak was coming from? I seem to have the same problem.
Old 11-21-2004, 01:51 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
There are freeze plugs inside, between the motor and transmission yes.
My Mopars
Old 11-22-2004, 07:57 PM
Re: Re: bell housing coolant leak
To options 13-There are 4 freeze plugs located between the trans and the motor.Two of these are low in the water jacket and any sediment in the cooling system will settle on these two plugs. There is only one fix, remove trans and replace plugs.They are cheap but this is a labor intensive job when done on your own.I know because I did this in one day .Good luck.
Old 02-12-2006, 08:01 PM
garyf garyf is offline
brass freeze plugs arent cheep but u wont be doing the job over in your life time ?
Old 02-13-2006, 04:37 PM
donwon37 donwon37 is offline
My wifes 96 Dodge Ram was doing the exact same thing,My mechanic said the timing chain cover was leaking he replaced the gasket along with the timing chain...Problem solved
