Old 12-15-2003, 07:16 PM
HondaCivic4358's Avatar
HondaCivic4358 HondaCivic4358 is offline
Send a message via AIM to HondaCivic4358
VTEC Toggle Switch Set-Up?
I have a few questions. Well number one, I have heard from a few people that using a toggle switch to run your VTEC is bad, but I have also heard that it will not hurt anything, what is the TRUE answer?
Another question I have is where would you mount your toggle switch? I have heard this is kind of a preference thing but I need some input.
And the third, final, and probably most major question I need to ask is, I have heard that like if you but and RPM activated switch, you can obviously set the RPM but it the VTEC will kick on once you have reached this RPM and it will turn off when you've reached this RPM, So like does that mean that when i hit say 4,800, it will turn on but then when I upshift it will turn off? Because you know that when you downshift and let the clutch out, your RPM's go down, but would they go below 4,800 or whatever your RPM activated switch is set at? I am probably gonna lose some sleep over this for nothing...
some help please thanks
Ryan
Old 12-15-2003, 09:52 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: VTEC Toggle Switch Set-Up?
hate to tell you, but if you had a stock ECU to control your VTEC, its gonna shut off when you shift anyway, unless you keep your foot on the gas when you shift.
what setup do you have on your car that would require you to manually turn VTEC on and off?
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-16-2003, 05:38 AM
A toggle switch, I havent done it yet but i am thinkin about it, but do you know if this would hurt your car cause i have heard several things
Old 12-16-2003, 07:36 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...why would you waste time mounting a toggle switch?? if you're gonna half ass..just half ass it with a rpm activated switch... a toggle switch is quite possibly the stupidest method.... you're looking at your tach..which probably isnt terribly accurate...by the time that crappy switch makes the connection... the timing is way off....and do you really want to be shifting and flipping a switch twice a gear? come on... you've got no hands left for the wheel
SOLD!
Old 12-16-2003, 09:42 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Why is a rpm activated switch half assing it?
Old 12-16-2003, 10:06 AM
marked001's Avatar
Moderadur
Re: Re: VTEC Toggle Switch Set-Up?
well..I didnt necessarily mean that... I meant, if you're not gonna use the proper ecu.... you may as well do the best thing you can do...especially b/c its fairly cheap...
SOLD!
Old 12-18-2003, 02:56 PM
Well i don't really want to change the ecu out. Or do i have too? I was thinkin actually about getting a summit rpm activated switch. BUT from what i hear though, you dont have to use the vtec if you dont wanna. and bt the way u can keep it on when u change gears i think
Old 12-18-2003, 03:42 PM
marked001's Avatar
Moderadur
..not sure if I understand your last post...but there is absolutely no advantage to leaving 'vtec on', as you put it... the performance is going to be horrible then down low...
and no..you dont really have to change your ecu out.. you may have a lean condition when vtec engages...but...not tha tbig a deal really..
SOLD!
Old 12-18-2003, 09:17 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
who the hell wants vtec anyways?? i doubt it does THAT much of a difference, thats why i'm just getting a DOHC ZC when i decide 2 get a motor. wont have to worry about all this vtec stuff, its much easier without it IMO, less hassle and less 2 go wrong
Old 12-18-2003, 10:08 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
if you could do anything besides use the correct ecu the best would be a vtec controller you could then change fuel as needed
but foreal i would just get the correct ecu setup and then a vtec controller if you want and get it DYNO TUNED!! it'll be worth the money
2002 Acura TL Type S
1991 Honda Crx Si
Old 12-19-2003, 01:05 PM
Bustamon's Avatar
Bustamon Bustamon is offline
Damn man, I'm gonna go to Autozone and buy a switch for $3.99. I'm going to keep my DX Ecu but every time I flip the switch I'm going to yell... BAAAAAHHHHHH! Out my car window. Yeah Yo DX VTEC POWER!
Old 12-19-2003, 01:06 PM
Bustamon's Avatar
But seriously don't use the toggle switch method man!
Old 12-19-2003, 01:58 PM
BullShifter's Avatar
Vtec aint all its said to be, IMO. People talk about Vtec & think their gonna have neck snapping power. It's just one more thing to have problems with.
Old 12-19-2003, 02:04 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
get a momentary cotact switch and put it under the gas pedal so you hit vtec when you floor it... LOL
LS1 RX-7 Zoom Zoom
Old 12-19-2003, 03:05 PM
kris's Avatar
Vtec is a great way to utilize a bigger cam lobe.
