Old 12-15-2003, 04:28 PM
crx hf crx hf is offline
Taking out the flywheel
KNow that i have my tranny out i wanna take out my flywheel to go get it resurfaced.How do you take it out.I dont have any bolt pattern to take out the bolts that are holding the flywheel.Any thing i should know before i attempt to take it out
Old 12-15-2003, 09:57 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: Taking out the flywheel
you need a 12 point socket, 17mm i believe
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-16-2003, 12:23 AM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
You will also need a 12 point 10mm socket for the clutch bolts. If you use a normal 6 side socket you might strip them.
DOHC ZC 89 DX HATCH
Old 12-16-2003, 12:39 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
yep what they said. when you put it back in the flywheel it is the cross pattern also the clutch is the same way.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
