Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-15-2003, 05:24 PM
Pagemaker Pagemaker is offline
Cruise Control Does Nothing...
I have a '91 Cutlass Ciera and the Cruise Control does not work.
It simply does nothing. I do not see any fuse for it.
Everything on the turn signal/headlight-dimmer/wiper control works except the Cruise Control.
I did use and test light and no wires going to the Cruise Control Motor have any power, so I'm assuming that it is in that control.
Has anyone had any Cruise Control Problems with this type of vehicle that they could point out? And maybe what it took to fix it.
Thanks!
Old 05-03-2004, 11:00 PM
torn132 torn132 is offline
Re: Cruise Control Does Nothing...
check the black cicular vacuum box under the hood could have a line that is breaking or worn they work off ofo the vacuum system hope it helps
Old 05-06-2004, 08:21 AM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
In addition to that black circular vacuum box (called cruise control servo), follow the vacuum line and it's T-fitting. The vacuum line is also used by another devices and so just check the T-fitting and follow the vacuum hoses.
The cruise control vacuum hose goes inside the vehicle and the vacuum hose goes to the brake pedal.
You may have to remove the cover below the steering column so you can see better and have access around the brake pedal. There is a button switch on the brake pedal and connected to the vacuum line. That button switch on the brake pedal is used to disengage the cruise control when the brake pedal is pressed down. Make sure that the button switch is fully pushed in (closed) when the brake pedal is not applied otherwise if the brake pedal is fully pressing on the button switch then the cruise control is disengaged all the time. Make sure the button switch vacuum hose is not loose.
Old 05-19-2004, 04:32 AM
ludakrissy ludakrissy is offline
Send a message via ICQ to ludakrissy Send a message via AIM to ludakrissy Send a message via Yahoo to ludakrissy
you know how off is in the middle right? well at your desired speed push it past off to the far left, then all the way back right and see if it picks up then... stupid sounding but it worked when i didnt have a clue
Old 09-27-2004, 10:32 PM
thejacobhartman thejacobhartman is offline
cruise control goes through abs fuse
Old 10-01-2004, 12:25 AM
djnoname djnoname is offline
Read on an older post that if one of your rear window brake lite bulbs is burnt your cruise wont work either. If all else fails check those.
Old 10-01-2004, 05:33 AM
wilfie27 wilfie27 is offline
could be the linkage on the throttle body
