Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-17-2001, 09:26 PM
brads94accord brads94accord is offline
Send a message via ICQ to brads94accord Send a message via AIM to brads94accord
Angry suspension popping?
well guys ever since i lowered my 94 accord lx on sprint springs on thanksgiving, my strut towers make this hisdeous popping noise whenver i put the car in gear, or hit the braks abruptly. does anyone know whats going on here? has it happened to you? my friend said its just settling, but it been almost a month now and its still doing it. i personally think its my stock struts that im riding on for now. until i save up enough money for some tokicos or kyb's. someone help. i poseted this on purehonda a week after i did it and got like two responses.
representin old school ph since april 2001, formerly UGAbrad94Accord
311 rules!
94 accord lx
16" konig reigns
3.25 inch drop on sprints and bec-techs.
clears all around, intake, custom rear section exhaust
farenheight plasma xenon headlights
click for my website
Old 12-17-2001, 09:31 PM
texan's Avatar
texan texan is offline
Writer Mod
You have checked the bolts for proper tightness, right?
'03 Corvette Z06
'99 Prelude SH
Old 12-17-2001, 09:38 PM
well i tightened them down really good. i tightened them once with an impact wrench, then came after and hand tightened them. theres only about 4 bolts to tighten.
311 rules!
94 accord lx
16" konig reigns
Old 12-17-2001, 11:33 PM
Rice-Rocketeer Rice-Rocketeer is offline
Are you sure the springs are sitting snuggly on the base of the strut and that the top of the springs is as well?
Lookin at my gucci, it's about that time...
Old 12-18-2001, 06:38 PM
yeah, they are sitting right in the little cutout things snugly. the sound comes from like the strut tower.
311 rules!
94 accord lx
16" konig reigns
Old 12-19-2001, 06:47 AM
JGM JGM is offline
Yea I had a popping sound in the back when ever i hit a bump just right. It went away after i replaced the shock with Konis. I think the trouble was that the spring was to stiff for the shock so on a hard bump the spring would rebound and the shock would let the car raise up off the spring then fall back making the Pop-Clunk sound. Hop these helps
Old 12-19-2001, 02:43 PM
mine makes it when i put the car in gear, like in the morning i'll put it in reverse to back up my driveway and when i put it in gear. and then when i put it in drive, it does it. it also does it when i stop abruptly. or today it did it when i took this corner really hard after i leveled out.
311 rules!
94 accord lx
16" konig reigns
Old 12-19-2001, 06:52 PM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
Well the sound you might be hearing is your shocks hitting the bumpstops from the drop.
Reducing your shocks travel will a drop like that eliminates its abilty to dampen the spring so it sound like you have a noise comming from your shock towers, when you kinda are.
Other than that does this happen when the wheel is straight?
Also are you sure it is not your tires hitting your fender walls?
M.Sanew - AutomotiveArticles.com
Old 12-19-2001, 09:30 PM
yeah, it makes it all the time no matter if the wheel is straight or turned. i happens at like a stop. when i put the car in reverse or drive it makes the noise like right as the car starts moving from a stop. or if i hit the brakes abruptly.
311 rules!
94 accord lx
16" konig reigns
Old 12-19-2001, 09:41 PM
Mod for life
1.) Try pushing down on one end of the car, is it easy to puch down, can you push it (you have to push hard) after you push down does it pop up with little or no movemnet or does it bouce up? How far can you puch it down, can you push it down more that 5-6"?
If so and it is boucey, probably a blown shock. Also if that reveals nothing
If you have a jack, put on the parking brake.
Jack up of of the front wheels slowely.
See if it creaks when the wheel is lifting off the ground?
when it is off the ground push on the top and bottom of the wheel (not left and right) push in and out, does it creak? If so it may be a wheel bearing.
Also with the wheel off the ground grap the shock and pull it left and right, does it creak? the spring may not be seated in the hat well or the shock may not be seated right. How does the lower fork on the shock look? Tight to the base of the shock?
Old 12-23-2001, 12:30 PM
well i jacked it up and tried moving it around and it didn't creak at all. it creaked when i lifted it up and when i lowered it down. i guess we'll know if it was the shocks if the sound goes away after i get new ones.
311 rules!
94 accord lx
16" konig reigns
Old 12-23-2001, 06:25 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
lube your bushings.
the car is lower than stock. it's now using more stroke of each moving assembly in the suspension, some limits never reached before while at stock height. this can cause some rotating components to squeak, creak, or pop.
Old 12-25-2001, 09:11 PM
Originally posted by drift
lube your bushings.
which bushings should i lube? any specific ones on the suspension? such as the ones on the sway bar? or just lube all of them?
311 rules!
94 accord lx
16" konig reigns
Old 12-25-2001, 10:09 PM
drift's Avatar
lube all of them on the suspension... if some are makin the noise, then all of them probably are dying from some grease.
Old 12-25-2001, 11:09 PM
what should i use to lube them? i have a tub of valvoline bearing grease in my garage, would that work?
311 rules!
94 accord lx
16" konig reigns
