Old 12-15-2003, 01:19 PM
atoyota4x4 atoyota4x4 is offline
98 Lumina Check engine light
Was wondering if someone could provide me with some info real quick. The Check engine light came on this morning while my wife drove to work. She said it kinda hesitated a little then it came on. Said it was fine the rest of the way. Anyway, I had her take it to a local parts place to get the code. They said it read a missfire on CYL 3. Told here it was either a plug or wire. No I just replaced both no but 5-10K ago. Put in AC Platnium plugs and AC wires.
Anyway, I don't have my book in front of me but does anyone know where CYL 3 is located? Front or backside? Please say Front!
Matt
Old 12-15-2003, 03:29 PM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: 98 Lumina Check engine light
Platinum plugs aren't good for these motors. They don't last very long. Since the DIS system that GM uses fires BOTH plugs on a coil at the same time, even if only one of them needs to fire. That's why I like to call it waste-a-spark ignition. It could be that the platinum has already burnt out in that plug.
Or it could be that it was just a random miss-fire. Is the Check Engine Light still on? If you have the code cleared..does it come back?
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 12-15-2003, 03:35 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: 98 Lumina Check engine light
Not true...Platinum plugs were standard in those engines..
#3 cylinder is located in the rear of the engine...
Misfire could be caused by a couple things..secondary ignition problem or possibly a injector fault.
Take a close look at the coil towers for signs of corrosion.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-15-2003, 03:41 PM
Re: Re: Re: 98 Lumina Check engine light
I'm thinking it might be a coil pack or whatever they are called. I'm going to look into it tonight. I will also check that plug and wire. I put back in it exactly what came from the factory so I know Platinum plugs are not the problem.
Old 12-29-2003, 12:18 AM
ciras3's Avatar
ciras3 ciras3 is offline
Hi,
I had the same problem with my Lumina. I did the spark plug, wire and coil pack thing as was suggested in the manual. It ended up being a clogged fuel injector. You'll have to take your car to the GM dealership and have them hook your car up to their cool machine. Your car will run great afterwards. Cost is a little over $100 for this.
C. Smith
"Just because the cat has her kittens in the oven doesn't make them biscuits."
Old 04-06-2004, 06:01 PM
SHADOW5683 SHADOW5683 is offline
I Need The Codes For 98 Lumina 3.1
