Old 12-15-2003, 08:02 AM
greg911 greg911 is offline
Angry Engine Idle Speed
I have this problem, I go to start my car and it will idle fine for like a minute then it will slow down to the point were it could stall , and then it does after another minute. Does anyone know what the problem could be. Thanks
Old 12-15-2003, 04:24 PM
SniperX13's Avatar
SniperX13 SniperX13 is offline
Send a message via Yahoo to SniperX13
Re: Engine Idle Speed
what year is your car? what engine is in it?
have you checked the EGR valve, checked the lines to make sure there isnt a vacuum leak. does the engine sound like its revving up and down, or is it just the gauge?
"Who are we to judge those, when we ourselves are afraid to be judged."
Old 12-15-2003, 06:54 PM
sjs92 sjs92 is offline
Mine had the same problem. It was the Idle air control valve. This was on a 98 24 valve Dohc taurus. It sits on top of the intake manifold. Right there on top. Very easy to change. My uncle owns a parts store, and he said that the this thing goes bad a lot on these cars. He was right. That was the problem. You can hit it with a hammer, and it will probably run fine for a while until it sticks again. It was 45 bucks or so from autozone and a little over 100 bucks from the ford dealership. Not saying this is your problem, but it could be. There are lots of other possibilites.
Old 12-16-2003, 06:41 AM
Ok, mine is a 92 does it still apply to what your saying because yours is newer, now the sensor that you are talking about, it it the grey contianer on top, cause I have seen that one.
Old 12-16-2003, 09:02 AM
SniperX13's Avatar
Re: Re: Engine Idle Speed
sjs... that sounds like something I need to keep in mind, as I also have a 98 with the tec in it. thanks for the info.
Old 12-16-2003, 09:23 AM
Re: Re: Re: Engine Idle Speed
OK does that mean that is the sensor that you are talking about?
Old 01-02-2004, 10:08 PM
speedy45 speedy45 is offline
I just want to take a minute to thank sjs92 for hive repley. My mothers car would not idle at all on it's own. She had the problem for about 3 months. I searched the net to see If I could find a hint on how to fix it. To my luck I stumbled upon this thread. I love the net! I took the valve out of the car. Sparyed a little break cleaner in it and hit it on my palm. This freed it up. I put it back on and it run great. Took all of 10 minutes. It takes a 10mm wrench or socket. Very easy to do for any one even if you have never worked on a car. Thanks a lot!!!!
idle speed control motor chris90deville Deville 1 08-08-2010 07:26 PM
2000 gt idle control/revving by itself wantaGTO Grand AM 2 11-19-2009 01:01 AM
engine idle speed mr_golf_je Blazer 1 04-11-2004 05:59 PM
Intermittent SES & engine idle speed fluctuations (99GT) Bruce123 Grand Prix 12 12-09-2003 07:04 AM
