Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 12-14-2003, 08:51 PM
Sachmo's Avatar
Sachmo Sachmo is offline
Exclamation Cold Start, Please Help!
I have a 1983 Celebrity 2.5l TBI. It virtually doesn't start cold, the warmer the engine is the easier it is to start, and etc.. I've replaced the plugs, plug wires, pcv valve, distributor cap and rotor, checked for spark, checked the fuel injector, replaced coolant sensor and tested tps(both were trouble codes)(tps was fine), fuel filter, cleaned the throttle body thoroughly(included idle speed motor). I've exhausted every possibility my feeble mind could come up with. This really sucks and I'm stumped. Any advice would be greatly appreciated. Thanks.
Jonathan
Old 12-16-2003, 08:37 AM
ra11585643 ra11585643 is offline
Re: Cold Start, Please Help!
How about the choke?
Old 12-16-2003, 02:16 PM
Sachmo's Avatar
Well it's my understanding that, being fuel injected, it doesn't have a choke. I wasn't very clear on that. Think it might be the fuel pump? It seems to inject fine when I take the breather off and watch it, but who knows?
Old 12-18-2003, 08:32 AM
RABarrett RABarrett is offline
Fuel injected engines do not require chokes as the computer controls fuel delivery based on engine parameters such as throttle position, airflow, coolant temperature etc. My suspicion is the fuel pump's condition. As it dies, less and less fuel is delivered to the TB unit, and the ECM cannot compensate for the dying pump. It has no way to know the pump is dying. When the engine is warm, the O2 sensor shows a lean mixture, allowing for enrichment. When the engine is cold or being started, the O2 is ignored by the ECM, due to its temperature. Ray
Old 12-18-2003, 08:41 AM
TBI is not regular fuel injection. Its not much more than a Carb without a float bowl. Injection takes place of the bowl, check the CHOKE !!!!
Old 12-18-2003, 08:45 AM
When you look into your throttle body you should see a butterfly valve, this is your choke plate. It should be open when engine is warm and closed when engone is cold.
Old 12-18-2003, 11:12 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Like Mr. Barrett stated in his post, the GM TBI injection system is controlled by the ECM, using inouts from the coolant, throttle position and Map sensors to calculate fuel delivery.
I would check the fuel pressure...should be between 9-14 PSI with the key on..I like to see about 12-13....any lower than 9...7-8 psi will allow the engine to run, but will cause difficulty starting cold and stalling on acceleration.
ra11585643 stated:
Both these statements are false! The Gm TBI unit has an injector above the throttle plate and the air is mixed with the fuel as it passes the throttle plate...there is no choke plate or any other choke type device on this setup.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-18-2003, 03:04 PM
Sachmo's Avatar
Thanks everyone, I dumped a small quantity of gas down the tbi's throat and she fired right, so I'm almost positive it's the fuel pump. Even though I have to drop the gas tank to get at it, it's a relief. I'll update when I put in the new pump.
Old 12-19-2003, 09:14 AM
This is jumping to conclusions. As GMMerlin stated, CHECK the fuel pressure first. There are several control systems involved in fuel delivery. Though the pump is involved, there are several control systems involved in its operation. That does not include the signals necessary to operate the injectors. Without testing, you are shooting in the dark. Age and time take their toll on ALL systems involved, not just the pump. Ray
Old 12-19-2003, 05:29 PM
Sachmo's Avatar
fine, I'll do it your way, I'll check the pressure first. Nonetheless, thanks.
Old 12-19-2003, 05:34 PM
GMMerlin's Avatar
I know stuff
Don't get pissy about it...spending a little time doing some diagnosis will save you money and time in the long run
GM WCT
PM Me for details
2000 Alero V6 will not start. Please help. slavetothought Alero 1 10-28-2010 08:45 AM
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 12:00 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
3.8 HARD Cold starts..Need Help please O.P Bonneville 10 03-21-2004 05:27 PM
