Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 12-14-2003, 12:33 PM
kitevector kitevector is offline
Heater Core Removal
I 'am Trying To Remov The Heater Core From 1999 Jimmy, I Have Reached The Black Box That Contains The Core ,have Removed All Screws And Nuts That I Can Find, But Their Has To Be A Hidden One Some Where. Can't Locate It. Can Anyone Help Me?
Old 12-29-2003, 09:20 PM
JeffL. JeffL. is offline
Re: Heater Core Removal
I just got finished replacing one over the weekend and I must say it was the worst one I've ever done.
The entire "black box" must be removed to access the heater core. There are two screws that are on the engine side of the firewall. To get to these, you'll need to remove the inner fender from the passenger side. Then you'll find 2 screws just behind the wheel. It helps to remove the wheel, but it's not necessary. Also there is one right beside the heater core pipes, but I'm sure you've already spotted that one.
GOOD LUCK!
Jeff
Old 02-09-2004, 07:00 PM
mricig mricig is offline
I would have never found these bolts without your post Jeff, Thanks.. Time to get rid of this blazer. The heater core in mine went 1 week after I changed the water pumb. what a pita.
Mike
Old 02-13-2004, 03:28 PM
Glad I could lend some help.
Jeff
Old 05-20-2004, 05:58 PM
jimmywithajimmy jimmywithajimmy is offline
Question Heater Core for 91 S-15
Is there any diff. between 91 and 94 for the removal of the heater core?Haviin' probs. too Thanks.
Old 05-20-2004, 09:06 PM
From what i remember it is a totally different ball game for 91-94. I think it should be alot easier then what we had to go through. In most cases on the 91-94 the core can be removed without taking out the dashboard.
They were very cleaver in hiding some of the bolts. The ones I had trouble with were behind the front right wheel and behind a black plastic cover that covered the evaporator for the ac.
I know it's not much help. I still have the gm shop manual on CD. if you would like I would be more then happy to mail you what it says for your model year.
after i fixed the heater core in the truck the flywheel cracked immediatly after. It had to go... I don't think i'll buy another chevy for a while.
Mike
Old 05-21-2004, 03:30 AM
Thumbs up Re: Heater Core Removal
Thanks Mike,that would be great!
Cash is tight this month.
I'd like to do it my self despite the horror stories I've read so far.
91 Jimmy S15 4.3 2WD AC
