Old 12-14-2003, 10:33 AM
aristotle99 aristotle99 is offline
Question 91 accord 4dr lx trunk leak
I am working on a 91 accord lx 4dr.the trunk is always wet i have tried sealing areas around the trunk and window however it is still wet.anyone have any ideas??? any help will be greatley appreciated.
Old 12-14-2003, 02:48 PM
BullShifter's Avatar
Re: 91 accord 4dr lx trunk leak
Is there rust on the bottom of the car? That could cause the inside to get wet. Have some one spray your trunk while you sit inside looking for a leak.
Old 12-14-2003, 07:42 PM
jheissle jheissle is offline
I have had the same problem, on the same car as yours for years. I have gone as far as sitting in the trunk while someone sprays a hose on the trunk and found no leaks. As the previous person states, it must be coming from the underside.
Old 12-15-2003, 09:55 AM
scarecrowdjinn scarecrowdjinn is offline
check your wheel wells,
accords often rust there allowing water to spin off the tires and up into the trunk.
Old 12-17-2003, 01:35 AM
accordztech accordztech is offline
Send a message via AIM to accordztech
you seal the lights yet? those are the likley cause..
yet umm...the seal for the trunk, sometimes those arent sealing right...it can be from there...
www.cb7tuner.com <---90-93 accord board
:for sale: left and right motor mounts for 4th gen accord. great condition
:strut bar, rear..no brace...
Old 12-31-2003, 01:59 PM
linksys9 linksys9 is offline
Lightbulb Water leak in trunk 4dr Accord
I've got a 4 door Accord EXR and had similar water problems in the trunk, usually after washing the car at a car wash, than I decided to take off the taillights and cleanup the dirt around the gasket and lenses, it worked for me, no more water problems! Give it a try?
Old 12-31-2003, 02:11 PM
Maple50175 Maple50175 is offline
Send a message via Yahoo to Maple50175
Yeah its the Tail lights water gets in from them.. I used a silicone sealent for it and bam no more leaks
