Old 12-13-2003, 09:38 PM
Spider151 Spider151 is offline
Unhappy '88 Civic w/ SOHC ZC hesitation/overheating/poor mileage
Hello,
I have a 1988 Honda Civic DX. The original engine blew so I put in a SOHC ZC not really knowing what/why. I had the same problems before I put in the newer engine too. I want to put in MPFI and do some other tuning but I want to make certain it runs well before I spend the cash!! Here are the symptoms:
1. studders on acceleration - I think you can here it pinging
2. it over heats - thermostat has been replaced 3 or 4 times - no 3.
change
3. eat gas like mad!
Again, these problems all existed on the orignial long block as well. I don't have others work on it but I did take it to two shops to help w/ trouble shooting and they couldn't figure anything out.
Any suggestions would be a big help!
Thanks,
Spider151
Old 12-14-2003, 08:11 PM
awwww, anybody got some ideas? I could really use any suggestions. This is my daily driver too, making it really difficult!
Old 12-14-2003, 08:28 PM
cot's Avatar
cot cot is offline
maybe check the radiator for a clog?
i assume new engine means new water pump, so that shouldnt be an issue
i believe overheating can cause pinging (kinda tough to decide which is the chicken vs. egg here)
Old 12-14-2003, 08:55 PM
Flush
It pings before it warms up. I am going to get the radiator checked at a radiator shop... maybe I should just replace it. They are only $125 for stock. It takes a long time though before it gets too hot. Regular driving, around town or below about 65 mph and it runs perfect!! Well kinda, she studders like crazy below 2500 rpm.
I didn't know pinging can be caused from over heating, thanks!
Old 12-14-2003, 08:59 PM
cot's Avatar
cot cot is offline
Re: '88 Civic w/ SOHC ZC hesitation/overheating/poor mileage
Sure - I'm not an expert but I've heard that if your car's overheating, the hot cylinder walls can cause early detonation (like a diesel I guess)
But that goes against the problem with power at low rpms. I assume there's no reason to suspect the timing of being off?
Old 12-14-2003, 09:14 PM
Re: Re: '88 Civic w/ SOHC ZC hesitation/overheating/poor mileage
No chance. I have been over the entire vehicle with a fine tooth comb. The only tools I don't have, that I'm trying to get, are a fuel pressure tester and a vacume pump/gauge.
I have even changed the cam timing - the low end still has trouble and the more I change it the worse the top end gets. Very weird.
*** Update Now the ecu is giving me code 16: fuel injection problem.
I think I should replace the injectors, it's only dual point. Beyond that I haven't got a clue, I have checked nearly every possible item... bad ecu?
