Old 12-13-2003, 09:17 PM
enzastigah enzastigah is offline
Question 91 Caravan Timing Belt
I recently changed the Water Pump on my van and i had to take off the timing belt to reach the water pump but now i have problems the van won't start i have a feeling i skipped some slots on the timing belt.I Really want to get it on time. Can you please tell me how to get it right on time perfectly fine. Thank you.
Old 12-14-2003, 10:59 PM
Chavo2005 Chavo2005 is offline
Follow the same procedure as you did to change the water pump. Remove the timing belt, replace if necessary. the Align all of your timing marks. the are on the two cam gears and the crank gear. go to
http://www1.autozone.com/images/cds/...3d8010c02a.gif
this is an image of the location of the marks. also make sure when you put the belt back on that none of the gears move Try again. also keep the tension on the "Tension Side" it is depicted in the picture.
I had the same problem when i did the water pump/timing belt on my 89GC
You can also go to http://www.autozone.com
then on the left Click Repair Info ->then Vehicle Repair Guides and follow the steps to choose your guide for you vehicle (ie. Year, Make, and Model)
