Old 12-13-2003, 08:37 PM
HondaCivic4358's Avatar
HondaCivic4358 HondaCivic4358 is offline
Send a message via AIM to HondaCivic4358
Exclamation I Need Some Help!!!!!!
i have 3 10 inch mtx blue thunder subwoofers and my STUPID friend pushed one in some but its not too bad. does anyone have any suggestions on how to pop it back out or is this even good to do when this has happened???????i would appreciate it thank you
~ryan
Old 12-14-2003, 12:49 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
take a pin and bend it at the end ...... push it carefully thru the dome until the bend is all the way thru, then straighten it up and pull as lightly as you can .... just enough to pop it out. Then you can put just a small drop of super glue to close the hole
Old 12-14-2003, 08:31 AM
Thank you. This woulnt affect the sound of the woofer at all would it? Because I got the dome out but you can still KINDA notice that its been pushed in a little bit?
Old 12-15-2003, 11:07 PM
Audio Guy
no, that inside cone is actually the equivalent of a mechanical crossover - it keeps a woofer from playing the higher frequencies. And yea, it's exceedingly difficult to get the entire dent out
Old 12-22-2003, 10:08 AM
Ok thanks you so much man
