Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 12-13-2003, 07:29 PM
stevevit stevevit is offline
Angry Problem with drum brakes!!
I have an '87 Suburban and I decided to replace the rear drum shoes but I've been running into a problem. I replaced the shoes and drum on one side but I'm having a problem with the other side. Seems like the brake shoe assembly cocks to the right (front) when I slide the drum over the shoes. I have the brakes adjusted all the way in and I've torn down the assembly 3 or 4 times switching left to right but I can't seem to get it right. I've tried putting the drum half on and trying to pry the assembley so the studs will go through but no luck. I replaced the wheel cylinder and both plungers seem to go in enough for it to work - I'm out of ideas and not sure what to try next. Any suggestion will be greatly appreciated. Thanks Steve.
Old 12-14-2003, 04:40 AM
a1supersport a1supersport is offline
Send a message via AIM to a1supersport Send a message via Yahoo to a1supersport
Re: Problem with drum brakes!!
Is the parking brake in the "released" position? Or maybe the parking brake cable on that side is frozen...just a thought .
Old 12-14-2003, 07:07 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: Problem with drum brakes!!
Make sure the shoes are in the proper position. Smaller shoe on the front, larger shoe on the back.
Next, check the strut that runs between the shoes to see if the shoes fit into the groove in the strut.
Make sure the park brake release cable is not frozen or adjusted in such a way that the shoe assembly is in the "applied position"
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-27-2003, 02:02 PM
I think nit might be my emergency brake, it seems like it might not be released all the way. I guess it's stuck and I can't figure out how to release it. I've engaged the emergency brake and released them several times. My truck is an automatic and I never really used the emergency brake but I'm pretty sure they were in fine working order before I took them apart.
Old 01-04-2004, 09:04 AM
dxrflyboy dxrflyboy is offline
Try prying the P-brake lever back. Make sure the cable isn't overtightened. If the cable is hanging up, replace it.
Dan
Old 01-08-2004, 08:44 AM
RABarrett RABarrett is offline
One other possibility is that the shoes were intended for a larger diameter brake drum. Anytime I have purchased shoes for anything, there were all sorts of questions asked about letter codes on the drum, shoe width and diameter, etc. The parking brake issue could be resolved the cable is slack. It is also possible for the self adjuster to stick, allowing you to believe it is fully retracted. Food for thought... Ray
