Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 12-13-2003, 04:52 PM
Scottie403 Scottie403 is offline
Performance Parts
I have just inherited a 1989 eighty-eight. I would like to beef up the engine because the stock hp just isnt enough. So if someone on here could please help me in finding performance part, because I'm having a hard time finding any. thanx
Old 12-15-2003, 02:18 PM
jon@af's Avatar
jon@af jon@af is offline
The Media Guy
Send a message via AIM to jon@af
Re: Performance Parts
Well, I have an 89 coupe Eighty-Eight. If you wanted to take on the challenge, you could make the engine a turbo by buying a grand-national turbo charger and do the necessary engine work and tranny work, not to mentiona new intake and exhaust; though you would have to find a different intercooler as they dont make the intercooler from the grand national anymore.
AF User Guidelines <----Click and read if you don't know these.
"Dream as if you'll live forever. Live as if you'll die today."
A Blog By Swigz
Cotidie damnatur qui semper timet; Aquila non captat muscas.
Old 03-07-2004, 03:14 AM
h3llphyre h3llphyre is offline
Re: Re: Performance Parts
You seem to think this is even remotely easy to do....
Old 03-07-2004, 08:27 AM
jon@af's Avatar
The Media Guy
Re: Re: Re: Performance Parts
My father is a technician, and I do know how difficult it is. Just because I didn't mention all the work required doesn't mean I do not know it has to be done. I never said it would be done soon or anything of the sort. There are many things I have to take care of before I start on my engine, but regardless, I still want to do the work.
A Blog By Swigz
Old 03-07-2004, 08:50 AM
Re: Re: Re: Re: Performance Parts
Oh, it certainly is possible, but many hurdles will need to be overcome before a system like that can work. First and foremost, is fabbing up a turbo exhaust manifold. This is required to be extremely high grade steel that won't melt or crack from the excessive heat generated by a turbo motor. The intake isn't a huge deal, as the stock one should be fine to use. An intercooler is not a problem in the least bit. It does not require a "grand national" intercooler. Any intercooler will work, and a large front mount would be the best route to take. Next, will be the motor. In order to be able to run any amount of boost that would be worth doing, it will require you to build a rather stout, forged bottom end with low compression pistons. The grand national used the FWD heads, so the stock heads should be fine. next, is the tranny. It will cost a decent amount of money to build that tranny to be able to handle the amount of power that the motor will be making. It may even be rather difficult to find components for that particular tranny. Then, you have the fuel system, which really isn't a huge deal. larger injectors, a larger fuel pump. Last, and probably the most important and maybe the most expensive is the computer system. You will have to go with a stand alone unit and tune it yourself... Nothing a laptop and some serious reading and experimenting won't solve. It isn't TOO difficult to build such a motor, it will just take a lot of research, getting to know some people who know what they are doing, and a lot of cash. Good luck on your ventures. let me know how it goes.
Old 03-07-2004, 11:23 PM
greengumby greengumby is offline
wow...dont forget the pics when it's done ...
Happy motoring!
Old 03-09-2004, 05:52 PM
jon@af's Avatar
The Media Guy
Re: Re: Re: Re: Re: Performance Parts
I don't plan on doing this for a while, but I do plan on doing it. I have to work on college first, THEN I can worry about my car.
A Blog By Swigz
Old 04-26-2004, 09:35 PM
Rage-X-2 Rage-X-2 is offline
Are there any NON turbo mods you can do to this motor to gain some power? I kept up with a mid 90's crown vic cab in my 88 olds 88, but i couldnt pass the bastard... this was with OD off and the go pedal FLOORED! (AC off of course) I NEED MORE GO! with out breaking my bank...
Old 07-17-2004, 01:59 PM
g6969m1 g6969m1 is offline
looking for an o-ring gasket for a 1986 grand national that goes between the oil cooler and filter? any idea where i can find
Old 07-18-2004, 08:52 PM
doctor_ill doctor_ill is offline
i'm interested in mods for a 90 olds 88'. i too have been trying to find some kind of performance parts without much luck. so really it seems to gain power you basically have to build an entirely new olds, and from what ive read above thats sounds real complicated.
Old 09-26-2004, 07:49 PM
wierd1001 wierd1001 is offline
Send a message via MSN to wierd1001
Hey Guys.
I was also at one time looking for performance parts for my olds. What I found worked good without breaking the bank...
for starters, on the older style olds there is no o2 sensor on the Cat. Cut it out. It made a huge difference especially out of the hole.
Not too long ago, I also tried going straightpipe with it for fun and actually lost power. 3800s seem to really like just enough back pressure. Look for a dynomax dual outlet camaro muffler. it gets rid of that annoying v6 rapping sound and gives you this awesome sounding rumble and a hella lot more passing and high rpm power.
On top of that, Order Ractive Cone Filter and get a 3" piece of piping and build yourself a cold air intake and remove the factory airbox. this made a HUGE difference.
With all that done, Im keeping with my buddy's 04 grand am GT. Pisses him off something fierce. lol. I have a 4 door with a bunch of stereo in the back too. Im thinking superchip is coming soon too. I will let you know.
Happy motoring!
Old 10-12-2004, 11:19 AM
ecarlson9973 ecarlson9973 is offline
1999 olds 88
I am just wondering what are the major differences between a 88 and an LSS powertrain. Obviously the blower, but are there a lot of other changes to the engine and transmition?
Old 10-12-2004, 05:42 PM
Ofnarcr Ofnarcr is offline
My buddy has an unknown flomaster exhast and he can get it to me for 20 bucks. I dont know if it'll work. I need to find out. Do you think that'll do nething? I am also interested in doing this kinda stupid things to my 1990 olds eighty eight royale.
Neone else notice with the auto tranny it shifts from first to second at 45 mph and 2nd to third at like 75 mph. Craaaazy stuff. Noone believes me. Neone know the topspeed of this mofo??
