Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-13-2003, 03:54 PM
racerchic racerchic is offline
Question 240sx corner lens
Does anyone know how the corner lens are removed in a 1995 240sx? I'm having problems removing mine. I have taken the screws out and have tried a little force but I'm afraid of breaking them. Any advice?
Old 12-13-2003, 05:45 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
Re: 240sx corner lens
This should be added to the FAQ or something. I've seen people ask it a couple times. I'm gonna go do it real quick and take pics then I'll come back and post them.
Old 12-13-2003, 06:05 PM
Ok here's the pics and here's how to do it:
First, remove the only screw holding in the corner light. I'm sure you've got this step since you said you were able to remove the screw.
Next is where you need to pry it out. It is held in by a little ball joint type lock and it's in there pretty good. I was afraid I was going to break mine when I first tried to take it out, but it just pops right out and doesn't break anything. Put a screwdriver in between the corner light and the headlight about an inch and a half above the bumper or so because this is where it will be the most effective when prying the corner light off. You can do this once the screw holding the corner light is removed. Then, push the handle of the screwdriver towards the headlight and the corner light will pop out.
And finally, here is a pic of the corner light out. You can see the ball joint on the corner light and the thing that was holding it in back in the car.
Hope this helps some
