Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-13-2003, 03:20 PM
amsjunkhead amsjunkhead is offline
electrical problem i think
The lumbar buttons on my passenger side control the lumbar on the driver side. How could this have happened and how can I fix it?
Old 12-13-2003, 05:15 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: electrical problem i think
When you adjust passenger side, the drivers side servo runs also. This is normal. Verify that it's actually moving the drivers side and then go from there.
Quality isn't expensive, it's priceless.
Old 12-15-2003, 09:47 PM
omegaic's Avatar
omegaic omegaic is offline
Keep in mind that the lumbar control is just 2 bags of air in the seats. The pump is located in the driver's seat and feeds both front seats.
01111001011011110111010100100000011000010111001001 10010100100000011100110110110101100001011100100111 0100
Old 12-16-2003, 01:35 AM
Indy8's Avatar
Re: Re: electrical problem i think
Once again, you are incorrect. There are no "air bags" in the seats. The lumbar is a lateral support device actuated by a servo. Sorry 'bout that!
Old 12-16-2003, 04:00 AM
jjdewd jjdewd is offline
Send a message via AIM to jjdewd
Lol
Old 12-19-2003, 06:58 PM
bustedratchet bustedratchet is offline
Sorry to disagree with you Indy I did some homework and The Aurora has 2 air bladders in each seat and one centralized pump under the drivers seat. The Riviera has a servo strap system.
Old 12-19-2003, 08:05 PM
Indy8's Avatar
Re: Re: Re: electrical problem i think
I have a 97 and if I push hard on the seatback, I can feel a bar(?) move behind the cushion. Maybe the assembly line ran out and I got the Riv's.
Old 12-19-2003, 09:00 PM
Re: Re: Re: Re: electrical problem i think
I looked up a 99 thats what mine is I'll see if I can check on the 97. Yours makes noise on the drivers side when the passenger hits the buttons ?
Old 12-19-2003, 09:29 PM
Indy8's Avatar
Re: Re: Re: Re: Re: electrical problem i think
Yep!
Old 12-19-2003, 10:14 PM
sha_zapple's Avatar
sha_zapple sha_zapple is offline
MY driver lumbar buttons dont work at all. The back window will not go down. The passenger side door does not unlock unless done manually.
These will sometimes work when the drivers door is open (not uncluding the passenger lock)
This car has a shitload of wires. Id hate to be the mechanic.
Old 12-20-2003, 04:28 PM
Indy,,, I checked on that a 97 is air bag seats. And shazapple speaking of shitloads of wires I would suspect a broken wire or two from the drivers door to the body. And some days I hate being a mechanic !
Old 12-20-2003, 04:44 PM
Indy8's Avatar
What causes the up and down movement? Does it inflate different "pockets"? It feels like a hard bar in there to me.
Old 12-20-2003, 04:47 PM
Just like an air shock system pumps up but also has release valves. One lower bag and one upper bag. They feels like a pillow on my sore back !
Old 12-20-2003, 04:53 PM
Indy8's Avatar
Since you're on now, how can I get my sentinel to work? Is the relay really up in the fender? How do I check it w/o an ohm meter?
Old 12-20-2003, 05:36 PM
Re: Re: Re: Re: Re: Re: electrical problem i think
I'll see what I can find out Monday, Our good pc isn't reading the dvd's. I'll try the standby it has the info just getting to use it is a pain. The headlights not coming on ? You don't have the switch the whole way down ? (had 2 ask)
