Old 12-13-2003, 10:31 AM
civichbca91 civichbca91 is offline
Send a message via AIM to civichbca91
Tachometer installation...
Hey again. I've figured out which blue wire i need to hook the tachometer up to, it runs into the back of a plug, which plugs into the back of the guage cluster. My question is this, since I am not going to hook that blue wire up to a tach in the gauge cluster itself, but a seperate tachometer, couldn't i just pull that blue wire out of the back of that plug? Or would it be better to cut it and leave a little sticking out of the back of the plug just incase i need to hook it back up for some reason?
Old 12-13-2003, 02:42 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: Tachometer installation...
Just use a wire splice connector. It will clamp on to it along with the wire from the tach, then if you ever want to remove it, it will still be attatched.
Check out my car here My 91 Hatch
