Old 12-12-2003, 05:06 PM
tom_indo tom_indo is offline
Send a message via AIM to tom_indo Send a message via MSN to tom_indo Send a message via Yahoo to tom_indo
no power to fuel pump
88 F150 still
no power to fuel pump. i used a tester and nothing. i ran a hot wire down there and the pump works and it acts like it wants to run now but will die after about one second. would this be a filter issue or something else?
Old 12-13-2003, 09:50 AM
pete54ford pete54ford is offline
Send a message via Yahoo to pete54ford
Re: no power to fuel pump
Best bet would be to change the pump. Sounds like its on its last leg. In tank pumps are a pain in the butt to, so I wish you the best of luck
Old 12-13-2003, 10:31 PM
the pump is in-line
it is a new pump and filter. could there be a reason the pump is not getting power? i tested the wires and there is no power to the pump. but i added a good hot wire to make the pump function and still not wanting to stay running.
Old 12-14-2003, 09:45 AM
Ah a new twist to the story. Sounds like the connection is bad, the only thing I can guess to do is chande it out...new wiring and connector, unless you can find the bad spot in the wiring and fix it that way. Best of luck to ya on that one.
Old 12-16-2003, 09:19 PM
fixed
it was the eek relay and the small ground from the battery was to the frame and needed to be in a plug that goes to the computer.
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
