Old 12-12-2003, 12:38 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
How bad of an idea was this?
I bought a complete engine wiring harness out of a 94 Civic EX.
Think this will make my hooking up the D15B any easier?
Honda Enthusiast
Old 12-12-2003, 12:51 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
Re: How bad of an idea was this?
If you have the cabin harness too it might help, otherwise im guessing it will be a pita to splice it to your dash harness.
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 12-12-2003, 12:53 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..possibly, b/c you'll have some of the updated plugs that go onto the obd1 engines..
SOLD!
Old 12-12-2003, 12:57 PM
Killa_CRX's Avatar
When Civics Attack!
That's what I was hoping... instead of having to cut and rewire so much stuff... was thinking maybe 'most' of the engine harness will plug up to the D15B and ECU, and I can just make corrections where needed (such as dash and interior harness) which doesn't nearly bother me as much as trying to get the ECU and everything hooked up and wired up correctly.
Honda Enthusiast
Old 12-12-2003, 05:15 PM
91civicDXdude's Avatar
the only thing the harness is good for is using the plugs to splice onto your current wiring harness. you cant use that engine harness as the main plugs are different...unless you'd rather splice every single wire to use the obd1 engine harness instead of just a couple plugs...
Old 12-12-2003, 05:49 PM
Killa_CRX's Avatar
When Civics Attack!
well, I'm hoping to get my hands on every wire and plug between the front of the engine and the ECU.
So I'm not going to be able to just take out all of the 91's wiring harness and replace it with the 94 wiring harness?
Honda Enthusiast
Old 12-13-2003, 09:59 AM
no. like i said the main connectors are different, so unless you feel like splicing every single wire from one king of main plug to the newer style, you'd be better off replacing the couple of engine plugs that are different.
Old 12-13-2003, 12:26 PM
Killa_CRX's Avatar
When Civics Attack!
Ok, I see what you're saying.
It's just going to be a bitch wiring either way I go.
Honda Enthusiast
