Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-12-2003, 11:47 AM
Larryincommerce Larryincommerce is offline
1991 Rodeo
1991 with 250,000 miles.
The Rodeo died while I was on highway.
No warning lights, noise or any other warning.
After pulled over I tried to re-start. Engine barely turned over. Sounded like a dead battery. Replaced battery-car cranked. I drove it home (approx 10 miles) with no problem. After I got it home I killed it and restarted. No problem. Let it run for a few minutes and tried same thing again. Dead battery sound again. Next day started the car and it started immediately but only ran for a few seconds. Did that 2 more times. Now sounds like it is running out of gas. I think something is shutting it down but I have no idea what that could be or how to go about figuring it out.
Last car I knew how to repair was a 350 Chevrolet.
Old 12-13-2003, 08:28 PM
paulsantangelo paulsantangelo is offline
Re: 1991 Rodeo
Hey there:
Just a question: was there any bucking? I read on the internet (a google search) this guy found that the engine ground was held on by tape and that when the engine virbrated the eye ring would come away from the engine. If you need the website I can look it up! BTW I ve a 92 with 213000, Nice job! Dont' give up! -Paul
Old 12-14-2003, 10:18 AM
surferfletch surferfletch is offline
Re: 1991 Rodeo
Original alternator?
Old 12-15-2003, 07:04 AM
Re: Re: 1991 Rodeo
Originally Posted by paulsantangelo
Hey there:
Thanks. No bucking, it just quit.
Radiator wasn't hot and checked the oil level. It was fine.
Old 12-15-2003, 07:08 AM
Re: Re: 1991 Rodeo
Yes, original alternator.
Do you think that might be it? I am beginning to believe it might be the alternator or charge relay, but there hasn't been any engine light or other sign of a weak battery.
Old 12-15-2003, 05:54 PM
Re: 1991 Rodeo
I have limited repair experience, but I'm thinking it might be worth a run to the auto parts store to rule it in or out.
Old 12-15-2003, 06:29 PM
ibew595's Avatar
ibew595 ibew595 is offline
Send a message via AIM to ibew595
Re: 1991 Rodeo
Sometimes when the battery takes a crap it will take the alternator with it. Remove it and have it checked out.
email"A.F."in subject line only
Mt. Hamilton 9/03
Kevin Goto
2000 740 i
Impala Brown
Annalisa
Old 12-15-2003, 06:53 PM
Dober89 Dober89 is offline
If it isnt the alternator how about the fuel filter?? I had an older car that would just die for no apparent reason in the middle of driving. I change the fuel filter and it never happened again.
Old 04-05-2004, 12:32 PM
Re: 1991 Rodeo
Well, it was the Alternator. Funny thing, as soon as I changd the Alternator the teperature gauge started working again. It quit a few days before the Alternator did.
Old 04-05-2004, 05:49 PM
Re: 1991 Rodeo
Glad to see you solved it. I wonder if that's why both my voltmeter and temp guage don't work...
Old 04-06-2004, 06:12 AM
Would not be at all surprised.
Old 04-09-2004, 09:08 PM
xxcrowleyxx xxcrowleyxx is offline
Re: 1991 Rodeo
in-case u didn't know it now there's electronic sensors on the cars nowadays, oxgyen sensor, map sensor, throttle position sensor, speed sensor, tempture sensor,. & there are a few others that i haven't come across yet. but these are the main ones. if any one of these goes bad (i mean dead) except for the speed one, the car/truck will not start..
we had a 80' & 84' amc eagles then we got a 89 bronco II & a 89 sunbird & ever since then we learned about these "dam-ed" sensors. ever since 86 or 87 the govt made a dead line for all auto manufactures to conform to a clean emissions policy & these sensors were bornat least that's the way i "red" it...
-scott
Old 04-10-2004, 01:20 AM
DJTME DJTME is offline
Just a quick tip to test your alt. Check you batter with the truck off with a DC voltmeter. It should read around 12 VDC. Then start the truck and recheck the voltage, the Voltage should go up roughly 2vDC.
Old 04-12-2004, 10:23 AM
Re: 1991 Rodeo
Thanks I will remember that.
