Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-12-2003, 10:00 AM
paulbdiver paulbdiver is offline
1993 4 wheel drive won't engage
I have a 1993 Eddie Bauer with 202,000 miles on it and I love this truck. However, my 4 wheel drive has decided to stop engaging. I had a problem with it last year in that you could press the buttons, the relay in the back right wheel well would tick, tick, tick, and then give up. I found info on various forums about how to remove the small shift motor on the transfer case, dissassemble & clean it, remount etc. I did that at it worked great... all through the summer. Now that a huge artic storm is bearing down, a new problem has occured. When I press the dash button, I don't even get the relay tick, no flashing lights, nothing. I've check the giant fuse in the power distribution panel near the battery and it's fine. What should I check next?
Old 12-13-2003, 11:18 AM
rjay rjay is offline
Re: 1993 4 wheel drive won't engage
Common problem in 93 especially in winter when you need it most,they say need New shift motor Not, so it can go out again ford knows about this problem too. Years ago
Old 12-13-2003, 07:10 PM
bustedratchet bustedratchet is offline
Re: Re: 1993 4 wheel drive won't engage
Did you remove the motor or the circular thing behind the weight ?
Old 12-17-2003, 10:43 PM
Blazr2 Blazr2 is offline
Send a message via AIM to Blazr2
Same problem here
I have the same problem with a 91. Fuses check out ok . I have no light at the 4WD switch now. I cleaned the conections at the transfer case and taped on the solenoid motor (Was told the brushes in the motor can hang up) The red light comes on in the relay in the storage compartment back in the rear cargo area and I here a clicking noise there but I still have no light at the dash. I think the solenoid motor is bad. If anyone has advice please help! I also had a push buton 4WD in a Bronco II and it worked fine until you needed it. My old trucks with the lever on the floor always worked!
Old 12-20-2003, 11:20 PM
Installed a used acuator motor or solenoid motor as some call it. Got it from a yard for 75$ .. 4 WD is working again! Not that dificult to install.
Dealer wanted 315$ for the part! Hate to think what they would have got me for labor!
