Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-11-2003, 10:50 PM
roo roo is offline
Send a message via AIM to roo
Steering Wheel Bit Loose
Any Info On How To Tighten Slightly Loose Steering Wheel? I Read The Other Posts Though Did Not Find Any Plastic Pins. Only Two Round Metal Pivots With Threads On The Inside. I Went To Dealer And Was Told I Have To Take It All Apart And Tighten Some Bolts Inside. Advise.
Old 12-12-2003, 01:44 AM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Steering Wheel Bit Loose
I have the same condition and would love to correct it also.
Quality isn't expensive, it's priceless.
Old 12-21-2003, 05:59 PM
roo roo is offline
fix
gona take it apart and fix it. will let you know.
Old 12-21-2003, 06:04 PM
Indy8's Avatar
Re: fix
Excellent! It makes an otherwise solid car feel like junk when you have play in the wheel.
Old 12-21-2003, 06:41 PM
bustedratchet bustedratchet is offline
Re: Re: fix
I've done many steering columns but never an Aurora. On other models there are 4 inverted torx bolts that come loose. Take the plastic cover off and wiggle the wheel you'll see where it is.
Old 12-21-2003, 06:47 PM
Indy8's Avatar
Re: Re: Re: fix
Past threads have described the freeplay to be around the collar/hub of the base of the steering wheel, does that sound right? Or is it further down the shaft?
Old 12-21-2003, 07:21 PM
Re: Re: Re: Re: fix
It's past the steering wheel . There is a flange that bolts to the steering column the shaft goes through it. The flange then has ears on it where the pivot point connects to the upper part of the column. In my experience the lower flange bolts are what come loose. But Indy I've never done an Aurora but I cant see it being much different. A lot of guys will only get it there and tighten 2 bolts when there is 4 much more work to do the 4.
Old 12-21-2003, 07:30 PM
Indy8's Avatar
Re: Re: Re: Re: Re: fix
Got it... Thanks!
Old 12-21-2003, 08:07 PM
BKVic's Avatar
BKVic BKVic is offline
When I was in the ARMY in 1990 I bought a 1988 Pontiac Firebird and after a few months the adjustable steering wheel started to loosen up. It got so bad I could pull the wheel to me while setting in the drivers seat without the key in the ignition and start the engine! The colume would still be locked so I couldnt turn the wheel but I thought that was kinda funny. Doesnt have anything to do with our Auroras but still a good story!
BKVic
Old 12-21-2003, 08:33 PM
Bill V Bill V is offline
The Aurora column is different than the old standard tilt unit that would loosen at the mount.
These units get sloppy when the pivot pins walk out. The right side is easy to re-install and re-stake, but the left one is behind the multi-function switch, so be careful when you drive the pin back in...
Old 12-22-2003, 06:07 AM
Re: Re: Steering Wheel Bit Loose
Bill,,, Sounds like this can be done by removing the upper and lower plastic cover and get right to the pivot pins without removing the steering wheel. Sure sounds a lot easier to do than the old school ones. Is it the left side that comes loose first ? I know I'm guilty of pushing on the left side of the wheel when I get out of my car.
Old 12-22-2003, 10:11 PM
Yeah... Just need to remove the upper and lower shrouds to fix this one. The left side does seem to be the first one to come out.
Old 08-28-2021, 12:42 PM
kiway22 kiway22 is offline
Send a message via Yahoo to kiway22
Fixing loose steering wheels are big business among Virginia's inspections, where i live. Some where around $500 dollars a pop. I had a lot of play, in my steering wheel, if you move it up or down. This is caused by those 2 steel pivot pins. on each side of the steering column. Over the years, the cheap metal ( old timers call it pot metal ) around the pivot pens. Causes the holes to get a little larger, but not much. I took a pivot pin to a machine shop, and got 2 made. Just 1/16th larger, and made the holes in the steering column. Exactly as the outside of the new pivot pins. I used some small dremel cylindrical sanding drums. To enlarge the holes a bit. And then used small vise grip pliers with a exact sized drill bit. To twist through the holes. I didn't want to use a power drill. Because sometimes a power drill will wobble a bit, and mess your hole up. There is still some slight play, but not much. That steering wheel is heavy, so I guess you can expect a little play.
300M steering wheel shaking and pulling right?. sandrav0312 300M 1 08-07-2010 04:47 PM
steering wheel shaking, pulling to the right uspres2020 Escort 6 10-10-2009 05:58 PM
Steering Wheel Repair JDatx512 Tacoma 0 03-30-2009 12:55 PM
96 Town Car: Wierd Prob w/ Steering Wheel Button(s) LieutenantCracker Town Car 6 03-05-2009 12:24 PM
Problem with the steering wheel Ennar Aveo 5 03-03-2009 09:11 AM
