Old 12-11-2003, 06:53 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Wider tires on stock rims.
I am about to get some tires and I am wondering how much wider I can go that the factory 185 60H R14 tires size without rubbing or having sidewall problems?
Old 12-11-2003, 07:21 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: Wider tires on stock rims.
Hard to say, check with the experts at the tirerack
Old 12-12-2003, 12:12 AM
Registered User
They only reccemend the stock tire size. I know that you can go a little wider but I want to know how much.
Old 12-12-2003, 09:56 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
Are you looking for a lower profile tire that is wider? The 185/60-14 is the lowest profile tire made for a 14" wheel. I guess it depends on how low your car is and if you're concerned about your speedo being incorrect...
Not to mention that most 14" wheels are only 5.5, 6 or 7" wide. I wouldn't go any wider than a 205 or maybe 215, but I doubt you'll find them in a 50-series (which would be closest to the size of your stock tires) for a 14" wheel.
Old 12-12-2003, 10:44 AM
Registered User
I talked to a guy at a tire place and he said that the widest I could safely go was 195 but I dont kno anything about tires. HE said they would be a little taller too. I dont really care about the height I just want more grip. Anyways would that be a noticeable improvement? or would it just be something that is in my mind?
Old 12-12-2003, 10:55 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Thumbs up
195 is the width of the tire in mm - so it would be 10mm wider than your stock size...and yes...that is about as wide as you can "safely" go...If you go more than one size wider (or narrower) than the designed tire size for given wheel, the tire bead and shit doesn't seal right, etc.etc..and I've seen extremes and wonder how the hell the tires stay on those tiny ass wheels (I live in Redneck country and see all kinds of weird shit )
As for them being a little taller that is because the 60 in the tire size is the sidewall height...it is in relation to the tire width...in this case 60% of 185mm...60% of 195mm would be roughly 6mm taller, so not much, given 25.4mm = 1inch.
I personally think 185/60s are too low profile and look silly...my Dad has those on his DelSlow, and I think 185/65s would fill the wheel well a little better, without looking all big and funky like 70 series tires do at 185 width...
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 12-12-2003, 03:40 PM
Registered User
THANK YOU! OKay I was basically wanting to know that when I get my coilovers it will look normal and not all rednieckish.
