Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-11-2003, 02:45 PM
gmc gmc is offline
keyless entry re-program
Does anyone know how to re-program a keyless entry remote for a 1997 bonneville?
Old 12-13-2003, 05:05 AM
markwb's Avatar
markwb markwb is offline
Re: keyless entry re-program
Do you mean "re-program" after insertion of new batteries? If that's the case then you would aim the fob at car and depress the lock & unlock simaltaneiously. This re-initializes the routine for keyless entry.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 12-14-2003, 07:41 AM
gmc gmc is offline
No, I mean getting a new keyless entry and re-programing it to the receiver of the car.
Old 06-04-2004, 05:41 AM
cabulldog cabulldog is offline
first make sure you have the correct keyless remote check with your local dealer then if correct do these next 6 steps before starting procedure get a fused jumper wire #1 turn ignition switch off #2 using a fused jumper jump terminal 8 blk/wht to terminal 4 blk on the data link connector close all doors #3 turn ignition switch on door locks cycle #4 press and hold lock and unlock buttons on the remote hold for about 30 seconds or so locks will cycle again #5 to program another remote repeat step four but during this whole process DO NOT TURN KEY SWITCH OFF #6 disconnect your jumper wire from the data link connector now at this point it is okay to turn ignition switch off but not until this point
