Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-11-2003, 12:50 PM
lowrightor lowrightor is offline
Send a message via AIM to lowrightor
Help me understand camber better
My car is lowered about 1.5 inches (according to Eibach).
I just got an alignment so here are my camber readings:
FL: 1.1
FR: 1.3
BL: 1.8
BR: 2.4
The inside edge of my tires definitely wear quicker but my mechanic said that he needed to correct the toe a bit so maybe that was what was causing most of the wear.
Is the difference between the BL and BR make you think something is bent or is this kind of difference normal? What would you do about it?
My 2000 Civic EX Coupe
Old 12-11-2003, 03:48 PM
chixSI's Avatar
chixSI chixSI is offline
Send a message via AIM to chixSI
Re: Help me understand camber better
One question...are you using your car for track use? if so...here is an approx. camber setting FR -1.0 FL -1.0 the BR -1.0 to -1.2 same for both. if you are using your car for everyday, FR and FL -.5 BR and BL -.5 to -.7
my explanation for this is when you make a hard right or left turn, your car will have slight body roll no matter what suspension you have. causing the neg. camber to become closer to zero. this mean your cornering would be improved because you are using nearly 100% of the tire thread.
i hope i answered your question!
chixSI a.k.a *jennie*
***Never Drive Faster Then Your Guardian Angel can Fly!!!***
www.teckademicseast.com
www.teckademics.com
www.dtmpower.net
www.motivonline.com
www.importvelocity.org
: TURBO is now in...
Old 12-11-2003, 03:58 PM
Re: Re: Help me understand camber better
Not for the track. Daily driver with occasional harder, fun twisty driving.
I know that there is often no one correct camber setting (or any setting for that matter). I also know why a little negative camber is good.
What I do need to know is if having such a difference from left to right side is normal and what are the advantages of having wheels closer to 0 camber.
Old 12-11-2003, 04:22 PM
chixSI's Avatar
alright babe from what i understand it sounds like you need to get a four wheel alignment.
and it is always good to have a little neg. then positive. and i told you pretty much why it was best to have the camber closer to zero because when you take a turn and it's zero then it becomes neg. will be using the inside which will improve your cornering.
www.teckademics.com
www.dtmpower.net
www.motivonline.com
Old 12-11-2003, 04:32 PM
and it is always good to have a little neg. then positive. and i told you pretty much why it was best to have the camber closer to zero because you will be using the inside of the tire thread which will improve your cornering.
1. Babe? Riiiight.
2. Your post makes little sense to me. Please try to clarify.
3. I just got an alignment. That's why I have my camber stats and why I'm posting this. Alignments don't affect camber.
Old 12-11-2003, 05:50 PM
T!mmy T!mmy is offline
Send a message via AIM to T!mmy Send a message via MSN to T!mmy
haha sorry I just thought it was funny how the girl was trying to make the guy look like an ass but in return....
The Dr. tells me too much masturbation is unhealthy...So when is "too much" masturbation "too much"???
Check out our car club site which I made http://www.almostperfectcc.com
Originally Posted by 18c5sol94
we go from a stop he pulls a little on me (only cause i can't keep the wheels on the ground)
Old 12-11-2003, 06:26 PM
Which girl? My name is Adam and this other guy is an illiterate who makes little sense.
Old 12-11-2003, 09:13 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Toe is a bigger wear of tires than camber. Heck I've had my car dropped 2" with:
FR: -2.7
FL: -2.7
RR: -2.0
RL: -2.0
My tires have over 15,000 miles and still look purty. But I rotate my tires every 3000 miles.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 12-11-2003, 11:15 PM
BullShifter's Avatar
Re: Re: Re: Help me understand camber better
Originally Posted by lowrightor
Which girl? My name is Adam and this other guy is an illterate who makes little sense.
chixSI aka Jennie - i think thats a chic - she made a good point about camber change in a turn . . . .the post is called "help me understand camber better"
Like I said before, check for bent/broken suspension parts on RR. Thats odd with that much difference, possibly the alignment rack was messed, check it again on the rack - if its not charge.
Old 12-12-2003, 07:15 AM
Re: Re: Re: Re: Help me understand camber better
Ah, OK..."this illiterate guy" is a girl. Got it. I did think she made a good point, but her last post I couldn't really understand.
You said you rotate your tires every 3 miles. What pattern?
Regardless, I will get the car on the alignment machine again to check the readings and be ready on hand with some washers to bring the Fronts back a little under 1 and the rears to more like 1.5.
Old 12-12-2003, 04:34 PM
chixSI's Avatar
sorry i confussed you, but i was actually at work and my boss behind me so i was trying to hurry it up...sorry for trying to help you out! And yes i am a girl who know alot about cars, but i'm still learning and want to learn more so instead of being rude you guys can just simply correct me and help me understand better. It's all good though! later
www.teckademics.com
www.dtmpower.net
www.motivonline.com
Old 12-12-2003, 04:59 PM
Jennie, Goddess of Camber Knowledge -
Quit taking it so hard. When I said illiterate, I meant a knowledgable-girl-who-was-rushed-into-posting-something-that-made-no-sense.
You know I'm just busting your proverbial balls. Thank you for the camber explanation. Much love.
In other news: I have a front strut bar and from what I've read it's not doing much and that a rear swaybar would help my handling much more. More "neutral" handling as they say. What do you guys (and girls) recommend in terms of brand and mm thickness?
Old 12-12-2003, 05:05 PM
chixSI's Avatar
ALRIGHT THIS IS WHAT I REALLY MEANT TO SAY:
alright from what i understand it sounds like you need to get a four wheel alignment.
and it is always good to have a little neg. then pos. because when you take a turn and it's zero then it becomes pos. camber which is bad. when it is set to neg. camber and you make a hard turn it becomes closer to zero which means more tire on the road which means better control and traction.
okay i hope you understood this and maybe it didn't help you out on what you were trying to ask for, but i gave it a shot!
www.teckademics.com
www.dtmpower.net
www.motivonline.com
Old 12-12-2003, 05:10 PM
Haha. That does make sense. Thanks babe.
I'm guessing this same concept applies to toe? Slightly toed in would be better than having it set to zero?
