Missing in Gear only???
Hello, I own a 1998 Rodeo with the 4cyl 2.2. The vehicle is 2wd and has about 95000 miles on it I bought it with 56000miles on it. I have not replaced the spark plugs (mainly cause I haven’t really found them) I have replaced both Oxygen Sensors within the last year. The check engine light has gone off and on at random for the last two years, I have grown to ignore it.
Within the last week a real problem has arose. The Rodeo will idle fine and I can even rev up the engine with no problems in neutral. When I put it in gear and take off, it bucks and feels like it might be missing but this only happens between 1000 and 2000 rpm's ........roughly. If I creep through the gears very slowly it runs fine. Its just when I put it in gear and push the gas peddle more than 15% down it gives me these problems and. I have been told it might be the idle air flow valve or something and I plan on changing the spark. I would also take any advice or tips on the spark plug changing.
The last problem I have is not a huge deal just annoying. On the tailgate of the Rodeo the little cylinder locking mechanism broke on me and fell into the inside of the door. So now I have no way of getting through this door because I can’t pop open the window. I have looked for fasteners and screws on the inside to remove the inside panel with no luck. I am open to any ideas here, preferably the least destructive. Well if you made it this far thanks for at least reading.
Ryan
