Old 12-11-2003, 09:23 AM
rossbush rossbush is offline
Engine Revs when clutch depressed
This is an intermittent problem, my favorite kind. My 1993 Ford Escort station wagon is a manual. SOmetimes, when I depress the clutch, the engine revs as high as 4000 rpms. Normally it drops off right away, but lately it has been holding steady at 3000 rpms or so. The problem is annoying, but I think also potentially dangerous. Probably, the vehicle will end up in a dealership unless I get some guidance. I am pretty handy mechanically, but I don't know where to start.
Old 12-16-2003, 05:43 PM
dan54 dan54 is offline
sorry i cant help, im in the same boat as you, i have the exact same problem with a gti escort, any info you recieve on this problem would be much appricated if you passed it on to me. thanks.
Old 12-16-2003, 10:50 PM
need4speed420 need4speed420 is offline
Re: Engine Revs when clutch depressed
try to bypass the clutch switch, it may be bad...... or it may be the speed control if it i locked in on position and the brake switch doen't work it make do that....... but try taking it to a shop and having them put a scan tool on it, that could give you the problem, and you can fix it easily.......
Old 12-19-2003, 12:14 AM
herefordman herefordman is offline
Idle Air Control Valve (IAC) on the top of the throttle body, could culprit. Disconnect the battery to reset computor and see if it goes away and then comes right back, if it does its the IAC.
Old 12-21-2003, 04:11 PM
andys79 andys79 is offline
Talking which pedal are you pushing..?
Try pushing the pedal on the other side.
heheheheheh.
Cheers,
Andy.
Engine revs when clutch pushed in budmax12 Avenger 0 06-27-2009 01:42 AM
94 5.0 Engine surge when shifting/depressing clutch vengeancecube Mustang Problem Diagnosis 1 03-16-2009 05:18 PM
2000 Explorer revs when clutch pedal depressed MattBG20t Explorer | Explorer Sport Trac 0 03-17-2004 07:34 PM
