Old 12-11-2003, 09:01 AM
keatonatron keatonatron is offline
Unhappy CD Changer problem...
I have a 12 cd-changer, JVC model KD-mk88. Problem is, last time I opened it to add some CD's, it made a bunch of noise then... nothing. The CD tray didn't pop out, and now the deck says "RESET 1" when I try to play CDs. Does anyone know if there is some way to force an eject? It seems like a simple problem, I really don't want to take it in somewhere...
Thanks.
Old 12-11-2003, 03:58 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: CD Changer problem...
try disconnecting the battery and reconnecting it. Just a thought
Old 12-12-2003, 08:29 AM
I tried unplugging the cable to the changer and plugging it back in, but that didn't change anything. I guess I might just have to take the changer out and take it apart, then remove the tray manually. The changer came with my car (I didn't install it) so I don't really know much about it. I guess I'll get to know it pretty well very soon
Old 12-12-2003, 08:21 PM
Haibane's Avatar
I didn't say unplug the changer
I said disconnect the CAR BATTERY. Usually makes a difference
Old 12-13-2003, 11:01 PM
Hmm... it could be a problem with both the deck and changer. I'll try that... But I can hardly bear to reset all my clocks and stored radio stations and the like!
Old 12-15-2003, 10:06 AM
I just took out the changer, removed the case, and popped the tray out manually. Problem solved. Quite easy actually...
CD changer problem grust Jetta/Vento/Bora 4 08-25-2005 05:17 PM
CD Changer Problems dawlfin817 Car Audio 2 04-09-2004 11:47 PM
CD changer problem krcl852 Car Audio 1 02-19-2004 08:03 PM
CD changer problem donseclipse Car Audio 0 12-24-2003 12:43 AM
Stock CD Changer Problem vik Accord/TSX/Accord Hybrid 1 05-14-2002 09:15 AM
