Go Back   Automotive Forums .com Car Chat > Games > Gran Turismo Series
Old 12-17-2001, 07:51 AM   #1
GT3 MASTER
gt3 tune shop get your best advice from me
I CAN TUNE ANY CAR UP TO THE MAX
GT3 MASTER is offline   Reply With Quote
Old 12-17-2001, 10:49 AM   #2
NSX
NSX's Avatar
Send a message via ICQ to NSX Send a message via AIM to NSX Send a message via MSN to NSX Send a message via Yahoo to NSX
hahaa
do you know how to change the settings, gear ratios, stabilizers, etc. etc.?
it depends what course you race
you could tune your car to race fastest on test course, or fastest on special 11
there's big differences
NSX is offline   Reply With Quote
Old 01-12-2002, 09:26 AM   #3
CorvetteMan
Banned
CorvetteMan's Avatar
Send a message via AIM to CorvetteMan
Talking COOL,help me please!
can you give me setting and etc,etc., for
corvette z06
camaro ss
toyota supra
viper gts
and nissan skyline
CorvetteMan is offline   Reply With Quote
Old 01-12-2002, 09:23 PM   #4
NSX
NSX's Avatar
Re: COOL,help me please!
what's your racing style?
drift?
tire-grip?
etc.
Old 01-12-2002, 10:00 PM   #5
CorvetteMan
Banned
Question re:to NSX
I don't know what my driving style is i guess fast and loose to normal.
Old 01-12-2002, 10:18 PM   #6
NSX
NSX's Avatar
well..do you like to a) slide around tight corners or b) brake and slow down...then cut inside and accel out?
Old 01-12-2002, 10:37 PM   #7
CorvetteMan
Banned
Thumbs up re:to NSX,B is my style
B,I guess is more me and what I usually do.:sun:
Old 01-12-2002, 11:39 PM   #8
NSX
NSX's Avatar
ok...one more question
do you like racing on courses like a) Rome Circuit, Grand Valley or b) Special Route 11, Deep Forest
this should determine your settings and which parts you should put on
Since you race with a tire-gripping style (like in F1), you should go with racing tires, TCS at lvl 5 ASM at lvl 10. This should help your car to keep straight when oversteering
Old 01-13-2002, 09:30 AM   #9
CorvetteMan
Banned
Cool A
A is my choice. :sun:
Old 01-15-2002, 11:22 AM   #10
NSX
NSX's Avatar
hmm...so you want to maximize hp instead of torque b/c of long straights. i forget what settings there are...i'll check them out for you
i think you should set your camber to a positive amount, TCS at lvl5, ASM at lvl10
just play around with the settings and restore the default if its not good
Old 01-15-2002, 02:06 PM   #11
Psman32@af
Send a message via AIM to Psman32@af Send a message via Yahoo to Psman32@af
umm covette man, dont follow these, there is no way to set camber to positive last time i checked. To maxamize speed, you should make sure that you dont have alot of downforce. do not have your TCS that high, unless you are using a fully modded escudo, all it will do is hurt you. My Zonda C12S wtih 1128 hp runs its best acceleration with TCS set at 3. I would suggest that you keep it at 1-2 with weaker cars and 2-3 with stronger cars depending on your taste. also i would suggest to not have your ASM at 10, that can also hurt you. I keep mine at about 2-3, depending on the car, track and tires. i would suggest raising your spring rates a couple units but keep them the same distance apart, run supersoft racing tires unless you are in a race with tire damage. Try that and get back to me and tell me if it has too much understeer or over steer.
2005 Mercury Grand Marquis. 230 WHP 249 ft-lbs as measured by a mustang dyno.
Psman32@af is offline   Reply With Quote
Old 01-15-2002, 02:40 PM   #12
NSX
NSX's Avatar
can you explain the different settings to me psman?
Old 01-15-2002, 03:36 PM   #13
Psman32@af
i'd be happy to explain what they all do, but i dont have the time to right now. I haven't even had a chance to race in the past 2 weeks. when i get some free time, ill type it up and tell you. Also ask if you want to see any of my times, cars or settings, just ask, i can post a pic if youd like.
Old 01-15-2002, 03:51 PM   #14
CorvetteMan
Banned
Talking Expain!
I will get back to you on that but please explain to me.thanks!
Old 01-16-2002, 11:12 AM   #15
NSX
NSX's Avatar
what car(s) do you use?
which courses are your favourite?
Advice from collision shop owners walleye_hunter Auto Collision Network 2 08-15-2008 09:43 AM
What if you get your first car from a Private Seller? Fredrick_NP Car Buying Q & A 2 04-13-2006 11:56 AM
whats your Best Performace shops in sacramento? HuNteR_X Off-Topic 1 03-31-2005 01:01 PM
Getting the Best Launch From an Auto..?? solaris=amazing Engineering/Technical 4 09-13-2004 09:35 PM
where did you get your short shifter from? bobbyd '88 - '91 Civic | CRX | Wagon | Shuttlee 15 08-18-2002 01:53 AM
