Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-10-2003, 08:05 PM
Mike Kline Mike Kline is offline
Dic
Just bought a '95 with 85k mi. and the change oil now is on even after I had the oil changed. Is there any way to reset it manually.
Old 12-10-2003, 08:33 PM
BKVic's Avatar
BKVic BKVic is offline
You have to reset the oil life monitor after you change the oil in your car, it does not do it on its own. Go to the drivers info center and set it to show the oil life left and then hold the reset button in until it resets. This is how I do it on my 97 and it should be the same for yours unless GM changed something.
BKVic
Old 12-11-2003, 12:52 AM
jjdewd jjdewd is offline
Send a message via AIM to jjdewd
Re: Dic
same on my "96"
Old 12-11-2003, 06:17 AM
bustedratchet bustedratchet is offline
Re: Re: Dic
Same on my 99 I think you push the engine button until the oil life comes on.
Old 12-11-2003, 08:55 PM
UKAurora UKAurora is offline
Re: Dic
Regarding the change oil/oil life indicator, my tranny oil life has been at 100% for 3 years!! Is everbody elses counting down?
Old 12-11-2003, 09:06 PM
Re: Re: Dic
Mine is at 100 for 2 years.
Old 12-12-2003, 12:48 PM
Re: Dic
Mine is at 100% since I've owned the car like 6 months.
Old 12-12-2003, 03:50 PM
oldsdad oldsdad is offline
Send a message via Yahoo to oldsdad
Re: Dic
I have owned my 96 with 93K miles for 3 months, trans fluid reads 100% but will have it changed at the first of the year. I am changeing all the fluids and to reset the oil life you press and hold the reset button for 30 sec. that will reset.too 100%
Old 12-12-2003, 07:09 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Re: Dic
Fram trans filter kit is $14.99, Dexron III is $6.99 when you buy the gallon jug. It takes you 90 minutes to drain, clean pan, change filters, and reseal. And that's taking it easy! A good idea to change it every 25k mi. Fresh fluid is critical to long life in an all electronic transaxle.
Quality isn't expensive, it's priceless.
Old 12-12-2003, 08:45 PM
dsatt12 dsatt12 is offline
I actually think the DIC monitors the transmission fluid somehow. I don't know if it is temperature or maybe turbidity, but when I had troubles I drove several hundred miles in 2nd gear to get it home. The fluid life indicator went from 100% to 59% during that trip. My guess would be temperature, but it is just a guess.
I do know I burned up that fluid pretty bad. It SHOULD have been reading 0% IMHO if that thing knew what was good for the damn car.
