Old 12-10-2003, 03:06 PM
jlcaskey jlcaskey is offline
Cool keyless entry programming
I just read the description for programming keyless entry on a 96 suburban and wanted to know if the procedure is the same for a 2000 LT or is it different.
Old 12-14-2003, 09:01 PM
99ssconv 99ssconv is offline
Re: keyless entry programming
Start with the ignition OFF, hold down the power unlock button on the door panel. Turn ignition key ON, OFF, ON, OFF. Release power unlock button on the door panel. The locks will cycle once.
Hold down the keyless entry transmitter LOCK and UNLOCK buttons for 15 seconds. The locks will again cycle once.
Repeat step #2 for each additional keyless entry transmitter.
Turn the ignition on to exit the keyless entry transmitter programming mode. Programming is now complete
Old 12-17-2003, 06:53 PM
nctnvol nctnvol is offline
Re: Re: keyless entry programming
Will this work on a 1999 Suburban also?
Old 12-24-2003, 05:14 PM
tombstone1880 tombstone1880 is offline
I read the programming for a suburban 1999 keyless entry. I could not get the programming to work on my 1998 suburban, is the procedure the same
Old 05-17-2004, 03:34 AM
Firetamer7 Firetamer7 is offline
Send a message via AIM to Firetamer7
Originally posted in another thread by "GMMERLIN" instructions on programming a 99 suburban-----
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
Remove the ground applied to the DLC.
Lock and unlock the doors in order to verify the transmitter operation.
Activate the rear window release in order to verify the transmitter operation.
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
'09 Corolla KeyFOB, keyless entry programming Question btrolla Corolla/Matrix/Voltz 1 09-03-2010 12:00 PM
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
