no heat
I have replaced the thermostat, checked lines they are ok. Still no heat could someone please help me
Re: no heat
no heat help
Re: no heat
heater core
well a bit more info would be helpful for a better response but ill give you my 2 cents anyway
sounds like the heater core may be clogged up, you can have it flushed at many different tune up shops or a local garage, when I do this i pull the heater hoses off and blow air through them with the air compressor and a rag to seal the air hose to the heater hose ..if you decide to do yourself Use very low pressure so you dont blow the seams out of the heater core, or youll be changing it anyway.. Drive Fast Or Be Last..................... |
Re: no heat
just wondering did you test the thermostat before you put it in.. i know of thermostats that dont work new.. so put them in a boiling pot of water and see if the valve opens
Re: no heat
If your cooling system is not clogged, and heater core is okay, check the heater resistor
