Old 12-10-2003, 04:21 AM
90hbvtec's Avatar
90hbvtec 90hbvtec is offline
Question need help b16!!
b16 goin in a 90 hb si
ok first i have a problem with the coolant sensor.. oh the b16 i have it is located at the back of the block, top of the oil filter .."looks like a battery in a way" and the plug ins on my stock si harness wont work what should i do?......the one on the b16 its not a harness it slike some kind of connectors..HELP!!!!..is the anyways to bake it work!!!
and another is my VSS the one on my b16 is a harness..so im think its a eletrical VSS..and the one on my stock si tranny is a cable line WHAT SHOULD I DO ... i NEED HELP!!!!!!!! ASAP....any alternative for it to work!
tru sohc vtec......
d16z6,ractive intake,ractive wires,msd ignition system w/blaster2
obx headers,pacesetter catback, w/test pipe,arospeed bomb muffler,tockico illumina shocks,r1 coilovers,GSR blades rims,ebay short shifter, w/neuspeed bushings,neuspeed strut bars front n back,ingalls camber kits altezza lights,indiglo gauges,proform shift light,integra center console..thats it for now...what else do i need...??ummmmmmm..TURBO..!!!!
Old 12-10-2003, 08:15 AM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
this is a B16a (1) right ?
the coolant temp sensor is located on the side of the block underneeth the Vtec Sylenoid. the one in the back of the block is a Knock sensor, oil pressure switch... and one more I can't think of. but everything will plug in using you stock plugs with the exception of, Knock sensor, 2nd O2 and Vtec wires.
as for the VSS you will see a bolt holding in the "harness" unbolt and rip that mofo out. (9 time out of 10 they cut the VSS cable) your stock one will fit right in.
Got it ? Good.
L8R
Kun
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 12-10-2003, 08:50 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: need help b16!!
hes right, its the knock sensor, you are gonna have to make your own subharness for that.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-10-2003, 09:51 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: need help b16!!
Well, I know some of our motors come with the coolant sensor on the t stat housing. So, you need to clip the two pronged wires, and wire ina plug, for the coolant sensor located there.
Old 12-10-2003, 09:23 PM
91zc 91zc is offline
The 1g b16a has a coolant temp switch on the back of the block as well. But I believe you are talking about the knock sensor whcih requires a subharness. You cna buy one from hasport or save the money and make one yourself. If your b16a came with the original harness it should be simple to make your own conversion harness.
91 civic 4dr
b16a
14.8@94
