Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-09-2003, 11:06 PM
tha_new_guy's Avatar
tha_new_guy tha_new_guy is offline
Nitrous/Turbo theories
I think that I have a basic understanding of both nitrous and super/turbocharging, but I am interested in the pros/cons of both.
Nitrous:
  • N2O is composed of one part Oxygen to two parts Nitrogen.
  • When N2O is split up into its separate elements, the reaction is endothermic in that it outputs less energy than originally invested into it, which creates a cooling effect on the intake charge.
  • Cooler air is more dense, allowing more air into the engine.
  • Nitrous can be damaging to your engine because...
  • Requires more fuel to avoid a LEAN air/fuel mixture upon ignition.
Turbocharging
  • The density of surrounding air is 14.7 psi at one atmosphere (atm).
  • A turbocharger functions by compressing air (belt-driven or exhaust-driven) into the engine.
  • Compressed air is hotter than normal, sometimes causing detonation.
  • Surrounding air is composed of roughly 21% oxygen.
  • Also requires more fuel to avoid a LEAN air/fuel mixture upon ignition.
MAJOR Effects
  • Since one is adding more air/fuel to a set volume (the bore of your cylinders), temperature is increased as a function of compression.
  • Engine internals are subject to break due to increased pressure in cylinders.
If the purpose of Nitrous/Turbo are to force more O2 into an engine, which does this more effectively? I have heard countless people say that Nitrous is much more destructive to your engine than a turbo, yet they both seem to do the same thing: more air in an engine. So I put forth this question: Is one method more damaging to engine internals than any other method? What can be done to prevent engine damage?
AF Bay Area Crew
"Please try to refrain from smoking crack while typing. The literate community appreciates your restraint."
AF User Guidelines
Old 12-12-2003, 06:36 PM
krebs128 krebs128 is offline
Send a message via AIM to krebs128
Re: Nitrous/Turbo theories
Nitrous:
  • true
  • this isn't a nuclear reaction, none of the compounds are splitting. N2O has a higher concentration of oxygen than plain old air. for example, 1L of N2O and 1L of air, both at the same temp, the N2O will have 36% oxygen while air only has 21% oxygen. so injecting N2O into your engine will result in more oxygen in the engine.
all true
Turbocharging
  • or commonly known as 1 bar (though technically it's 1.013 bar=1 atm)
  • supercharger-belt driven
    turbocharger-IS a supercharger, but a different type of supercharger that uses exhaust gases to spin the turbine, u got the idea pretty much
  • called 'knocking', and an intercooler is used to prevent that
pretty good
MAJOR Effects
and so that's y internal upgrades are a must when you're adding large amounts of boost to your car. stock car could handle 6-7psi or a 50hp shot of n2o.
though nitrous is the best bang for your buck, IMO i'd go w/ turbo. unendless amount of tuning and upgrades to get more h/p and effeciency. used properly, neither turbo or nitrous will do any damage to your car's engine. however, ppl over-use their nitrous, bad, or run their turbos at too high of psi, also bad. key to not destroying your car is play it safe-though u might miss out on some extra precious few hp. but in the end, if u play it safe, u'll still have an engine.
Old 12-12-2003, 09:41 PM
454Casull 454Casull is offline
krebs, the N2O molecule does split up like this:
2N2O(g) --> 2N2(g) + O2(g)
This decomposition does require heat and is therefore endothermic, but I'm not sure if that cools the intake charge. I DO know that the nitrous that comes out of the bottle is VERY cold, thus cooling the air it's entering.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 12-12-2003, 11:11 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
The majority of engine damage caused by either method is due to improper tuning, resulting in detonation. The increased cylinder pressures are not really a concern at streetable levels of boost. Detonation is the number one killer of turbo and nitrous motors.
Beer tastes better upside down.
Old 12-13-2003, 12:09 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
Re: Re: Nitrous/Turbo theories
well its not really the nitrous being cold its the fact that its an expanding gas(after exiting the bottle of course) and all expanding gases have an endotermic effect
i did not know that the chemical decomposition of the N2O is endotermic too
and patton is right the most important factor...and sadly often overlooked....its a proper A/F ratio...run too lean and it will not matter how strong your engine is when it will get detonation
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 12-13-2003, 11:43 AM
SaabJohan SaabJohan is offline
When something oxidizes (burn) we have an exothermic effect so it's quite natural the the reversed must be endothermic.
Nitrogen prefers to be in it's natural stage of N2, so the energy needed to separe it from the oxygen is quite small compared to the carbon and hydrogen in gasoline.
The separation of N2O happends under the later part of the compression stroke, that's also when most gasoline evaporate. This would therefore have none or a very small cooling effect on the intake air. The cooling effect on the intake air must therefore come from the expanding gas.
Old 12-13-2003, 11:13 PM
Re: Re: Re: Nitrous/Turbo theories
I said the nitrous coming out of the bottle was very cold, did I not?
Old 12-13-2003, 11:58 PM
Neutrino's Avatar
Yaya Master
Re: Re: Re: Re: Nitrous/Turbo theories
as a lawyer would say...."not to the best of my recolection"...
i'll stay with that
just joking...sorry in re-reading your post i can see that was what you meant....i was kind of surpised that you did not know that actually since you are obviosly quite knowlegeable about cars....well i was wrong my bad
now i'll go and ban myself
(\__/)
Old 12-17-2003, 12:19 PM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Nitrous is easier to set up.
cheaper, and can be turned off.
granted, a turbo timer will allow you to turn it off as well, but that is one more component whcih costs more money.
go with a 50 shot and have fun.
Old 12-17-2003, 02:03 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
WHAT?!?! After reading some of your post you've left me scratching my head. I can't resist on this one.
You can NEVER turn a turbo off when the car is running, it is impossible. A turbo timer is a device for lazy people that don't want to sit and wait for the car to idle down so they buy a device that lets the car run and shut of after a certain amount of time to save the turbo from toasting its bearings.
Old 12-18-2003, 12:36 AM
A turbocharger does only deliver boost when it's needed, just press the throttle and it starts to do the work. When running normal the boost will drop and the turbocharger will just "run along".
As for costs this depends much on how often/long the extra power is needed. To fit a turbocharger doesn't need to be much more expensive than to fit a nitrous system. Then there will be no refill charge.
Old 12-18-2003, 08:10 AM
when I said turn it off, I meant that you can buy a device that will bypass the turbo at a given RPM.
My friend has that set up on his 300gtVR4.
He called it a turbo timer and may have been incorrect.
regardless, he said it allowed him to set the RPM at which he would activate his turbo.
thus allowing him to "turn it off"
Old 12-18-2003, 11:17 AM
Polygon's Avatar
The Red Baron
Like I said, you can't turn off a turbo. If the car is running there is exhaust gas moving past the exhaust wheel in the turbo causing it to spin. Turbos do not activate, they spool. I already told you what a turbo timer does, and it does not affect when a turbo will spool.
Old 12-18-2003, 02:32 PM
ok fine.
have it your way.
Old 12-19-2003, 02:57 AM
The equipment that you are thinking of is called a boost controller, and it allows you to control the amount of boost created by the turbine. To understand how a boost controller works, read this; http://www.automotiveforums.com/vbul...d.php?t=145031 . After reading this it is obvious that by design of the boost controller, it can only increase boost pressure by leaking pressure from the signal line. In order to lower the boost, the boost controller would have to add pressure to the signal line, which no boost controller is capable of doing. Because of this, it is obvious that a boost controller can not lower the boost level below the level determined by the original spring rate of the wastegate actuator.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
