Old 12-09-2003, 10:43 PM
JeffL. JeffL. is offline
Headlight vibrates when in up position
My 2000 TransAm has a curiious problem...
When you drive with the headlight on or in the up position, the left one vibrates when you hit a bump. I wiggled each one while in the up position and sure enough the left one has some "play" in the arm.
Do these lights have a "stop" that they hit in order to hold them in a steady position or do they only rely on the stiffness of the arm that holds them up?
Thanks for any help,
Jeff
Old 12-20-2003, 06:15 AM
95fbodyunder3k 95fbodyunder3k is offline
Re: Headlight vibrates when in up position
they should have a cable underneath them and there is a stop next to the motor that the linkage hits so check all that and all the mouting screws there are a few
Old 12-20-2003, 02:39 PM
I appreciate the feedback.
Okay, I went and looked again. I found the "stop" on the motor itself, it rams right into it like it should, but I cannot find the cable (on either side). Is the cable what holds it steady? The passenger side is very stiff, but the driver's side assembly is loose in the linkage right where it hinges, not over a 1/16th inch of play, but enough to be a nuisance and cause the vibration. Should this linkage be very "stiff" or should it hit a "stop" somewhere other than the one on the motor?
Thanks for your help.
Jeff
Old 12-20-2003, 05:41 PM
1Formula 1Formula is offline
Pull the linkage off and whack it with a hammer at the rivet. Should be somewhat snug but it probably vibrates because the POS plastic gear in the headlight motor is probably going bad a common problem with these cars.
Old 12-20-2003, 05:49 PM
Go to www.camaroz28.com and to the message board. Then do a search for 'headlight fix' or 'brent94z' .
This guy has a web page telling you how to fix it without opening the motor and even sells bronze gears to replace the crappy plastic gear if you go that route.
Old 12-21-2003, 01:21 PM
yes it could be the gear if it is you'll know about it soon it will make a grindeing noise and the cable should be attached under neath the headlight it like a scondary stop
Old 01-15-2004, 03:00 PM
Just to give everyone an update. I replaced the arm that holds that head light up and it is now fixed. Once I got the old one off, it had a tremendous amount of "play" in it and the new one didn't. Now it is rock solid.
Thanks for everyone's help.
