Old 12-09-2003, 05:12 PM
gue55wh01t15 gue55wh01t15 is offline
Send a message via AIM to gue55wh01t15
motor mounts
will 1g motor mounts fit on a 2g motor in a 2g car? if not which ones will? What about the roll stop? are those interchangable?
"The only constant is change."
Old 12-10-2003, 07:13 AM
kjewer1 kjewer1 is offline
AF - Advisor
Nope. You need the mounts to match the car, not the motor. The 1g puts the motor mounts on the block, with jsut the one tranny mount to the far passenger side. The 2g has 3 on the tranny, and just one on the motor, driver side. You have to use the 2g drivers side motor mount, notched out to clear the 1g water pump See www.magnusmotorsports.com for more info.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-10-2003, 08:01 PM
mitsu-revolution mitsu-revolution is offline
Send a message via AIM to mitsu-revolution
Re: motor mounts
ummmmm..... gue55wh01t15 has the coolest car in the world but mines gunna be better some day
Metro Auto Trans Mount FUBAR ManicMetro Metro 1 01-11-2010 09:15 PM
Pass Motor Mount Plate - Stuck... pyro4329 2nd Gen 00-05 1 11-08-2009 03:22 AM
Z24 Motor Not Mounting To Motor Mounts Same Type Engine As Previous capnsquarters140 Older Pickups 2 02-12-2007 08:51 PM
motor mounts, tranny mount casinonut531 Grand Prix 2 05-03-2004 06:51 PM
motor mount - torque mount????? maxspeedhonda Engineering/ Technical 4 03-09-2003 01:37 PM
