Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-09-2003, 03:51 PM
flyinlowstereofree's Avatar
flyinlowstereofree flyinlowstereofree is offline
Question anyone got a turbo for sale??
I'm lookin for a turbo to put on my Dodge Daytona.
It's a v6 3.0L and I just need somethin...Garret... Mitsubishi..somethin like that.
Old 12-10-2003, 07:31 PM
SaabJohan SaabJohan is offline
Re: anyone got a turbo for sale??
You must define what model of turbocharger you want, or at least how many horsepower it should be able to give.
Old 12-11-2003, 03:39 PM
Well all I want is somethin to give me at least 4-8psi and works.They had turbo's on the 3.3L v6's they put in avenger's. I can make one work just need on first.
Old 12-11-2003, 04:16 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I am selling one, but I doubt you want it.
Old 12-11-2003, 07:09 PM
Re: Re: anyone got a turbo for sale??
Well, all turbochargers can give you 4-8 psi, but some does it with an airflow suitable for 100 hp and others for 2000 hp. So what we need to do is that we must find one that has a flow suitable to you engine.
Since you said 4-8 psi, that is about 1.5 bar in absolute pressure, multiply 1,5 with the number of hp you got in your engine and we will find a suitable turbocharger by looking at some compressormaps.
Old 12-16-2003, 03:31 PM
what you got polygon??
Old 12-16-2003, 03:34 PM
right now I have about 180 hp. working on a ram air hood. have a cold air right now. I'm lookin for somethin around 80 to 100 hp difference.Is that resonable??
Old 12-17-2003, 06:59 AM
In general we get a 50% power increase from 0.5 bar boost, this would then mean that the power would increase to 270 hp. For more boost the compression ratio must probably be lowered.
Since it's a V6 engine I recommend that you use two turbochargers as this reduce the length of the exhaust manifolds. A turbocharger suitable for this twin setup is Garrett GT17, it's more efficient, has lower turbine/compressor inertia and is made of fewer parts than the older Garrett T25.
If you want a single setup anyway I would go for MHI's (Mitsubishi Heavy Industries) TD04HL-16T-7 or TD04HL-18T-7.
A intercooler should be used, it's often possible to find and use intercoolers from light or heavy trucks or other machines that are using large turbocharged diesels. In many cases the intercooler must be downsized (requires a saw and welding equipment for aluminum).
The fuel system (ECU or carburetors) must be modified; how depends on the system used.
Old 12-17-2003, 01:36 PM
Polygon's Avatar
The Red Baron
It is a Garrett VNT 25. Small, but spools fast. Some people just don't seem to like the VNT turbos.
Old 12-18-2003, 12:54 AM
Re: Re: Re: anyone got a turbo for sale??
Could be because of that they don't like the hot exhausts of a gasoline engine.
With VNT 25 I suppose that you mean T25 with VNT. The GT series is also availible with VNT, for example GT2052V.
Two of those turbos should be able to do the job, and they will reduce lag and lower the boost threshold. How long the turbo will last is however the big question, car manufacturers aren't using them for that reason except on diesels which have a lower EGT.
Old 12-18-2003, 11:31 AM
Polygon's Avatar
The Red Baron
Re: Re: Re: Re: anyone got a turbo for sale??
Actually it is called a VNT25, which was the designation given to it by Garrett for Chrysler. Much like the T03 for Chrysler was different from the T3 sold to the aftermarket industry. However, it looks like it very well could be a T25 converted to a VNT type turbo it looks to be quite small. Also the only difference might be where the turbo bolts up to the exhaust manifold.
The turbo I'm selling is off a 1990 Chrysler LeBaron GTC Turbo IV.
Old 01-19-2004, 08:12 AM
2turboimports's Avatar
2turboimports 2turboimports is offline
i have a turbo i'm selling...probably waaaay too big for a daytona though lol..
it's a garrett straight T4 .70 A/R on the 'cold side'
.96 A/R exhaust side.
Old 01-19-2004, 08:20 AM
pics are in my gallery i don't know how to post pics yet....ohwell
Old 01-23-2004, 09:16 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Im selling a TA-49 precision turbo.... But its a 3 bolt housing for a turbo buick.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 02-21-2004, 06:44 AM
twin6g72turbo twin6g72turbo is offline
2turboimports email me at [email protected]
86 celica turbo 4 sale celica 86 turbo Classifieds 0 04-16-2009 02:42 AM
AutomotiveForums.com R34 Nissan Skyline GT-R N1 RACECAR for sale on eBay igor@af General Discussion 0 04-10-2009 03:43 AM
1996 chrysler town and country LXI for sale ford88mustang Caravan | Voyager 0 03-10-2009 08:09 AM
91 Syclone for sale must sell many mods!!! mazdaguy2008 Syclone | Typhoon 0 03-10-2009 03:09 AM
WTB: I'm looking to buy a cabrio anyone got one for sale? Tizzzony Cabrio 1 10-15-2005 04:45 PM
