Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-09-2003, 10:09 AM
mulepacker mulepacker is offline
How to change PVC valve?
My Ranger has 120,000 miles on it and I want to change the PVC valve?
I have personally never changed it before and don't even know where it is located on the 89 Ranger 4 cyl.
Any help is apprecdiated.
Thanks
Old 12-10-2003, 06:47 PM
EVH5150 EVH5150 is offline
I believe the PCV valve is located on the valve cover with a hose connected to it. Remove the air cleaner to get access to it and you simply pull it out of the grommet in the air cleaner. Once the valve is removed, check the hose also to make sure it's not plugged either.
good luck.
Old 01-01-2004, 08:28 PM
modification_inc's Avatar
modification_inc modification_inc is offline
Send a message via MSN to modification_inc
Re: How to change PVC valve?
I Own An 83 Ranger With A 87 2.3 And It Is Located Under The Intake Manifold Near The Distributor.
Old 01-09-2004, 07:01 AM
contagionxlt contagionxlt is offline
Send a message via MSN to contagionxlt
yupp
under the manifold behind the distriubtor. youll see a BIG nasty hose that seems to run off into nowhere... its in there. YUKKY job
