| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Alternator Repair
After washing my engine two weeks back , i killed my alternator.replaced the rotor and regulator on it.....working now and outputs 14.5v.....even as alternator is functional my ABS, BATTERY and i think CONVERTER/HEATER leds are ON, on the dashboard.....does anyone hav an idea how to fix this issue?
I don't know how you washed your engine, but I've never had that happen......
But for your problem, I think you have to replace the alternator. I think the real problem is the voltage regulator, but I believe that it is built onto the alternator, and can't be easily removed. Something similar happened on my dad's new truck, all lights would get real bright, and the ABS light would come on, and the voltage would go up to something insane like 16-18v. Ford just replaced the alternator to fix it. |
Re: Alternator Repair
I would think about replacing the alternator.
My question would be: How did you "wash" the engine? I've seen cars come in detailed by outside compaines all fucked up, even the pro's mess them up sometimes. You need to be very careful during the process & chemical selection. Did you use any silicone dressings? Tip: NEVER get the alternator or any sensitive electronics wet when cleaning. Clean those areas with a very mild chemical & brush/towel. |
